M5POST
      06-08-2014, 12:06 AM   #1
PetrolFumes
Drives: Raptor, GT3RS,E92 M3,X5M50i
Turbo noise when hard on throttle
Ok, so i just picked up a 2013 F10 M5 and it basically looks brand new. Has 1200 miles on it and i am noticing a slight buzzing noise coming from the turbos when hard on the throttle. Is this normal? Anyone else hearing this? I was thinking of bringing it in and getting it checked but wanted to make sure i wasnt paranoid first as this is my first non NA engine car and i am not familiar with the sounds the turbos should be putting out.
      06-08-2014, 11:39 AM   #2
Netwon
Netwon's Avatar
Drives: '12 BMW M5 Alpine White
2012 BMW M5  [0.00]
With the windows down when I punch it you can hear the sucking/spooling sound of the turbos. Kind of high pitched, stops as soon as you let up on throttle.
      06-08-2014, 12:52 PM   #3
smithy23
Drives: porsche panamera
Sounds like you may be hearing the active sound kicking in. Sounds normal aslong as the car is pulling hard you should be fine.
      06-08-2014, 03:03 PM   #4
PetrolFumes
Yes i hear that but i also hear a buzz kind of sound that sounds like it doesnt belong with the sucking noise.
      06-08-2014, 03:04 PM   #5
PetrolFumes
Active sound? Is there supposed to be a slight buzzing sound.
      07-01-2014, 08:56 PM   #6
PetrolFumes
Anyone getting this buzzing sound? Hear it when the throttle is at medium or higher and with windows down
      07-02-2014, 11:33 AM   #7
JM35
N54 Tuner
JM35's Avatar
Drives: 2008 135i 6spd
Probably just turbo spool, wouldn't think its anything to worry about.
2008 135i - 6MT - Jet Black
600hp 135i build blog
      07-09-2014, 10:15 AM   #8
DentalBoy
DentalBoy's Avatar
50
Drives: 2016 M6 Gran Coupe
I just purchased 13 M5 as well and hear a buzzing,whirring, electrical like noise at low speeds with window down. It is more noticable when the car is cold and seems to dissipate when warm? I took it to service, at first they couldnt hear anything so they eventually made me do a ride along and the sound was very clear. The mechanic said it is normal sound coming from engine? I am not convinced its normal, but whatya do??
_____________________________________________
2016 M6 GC under construction,2013 F10 M5 Akrapovic(sold)
2012 F10 AW 550i MSPORT,Vossen CV3s,ACS Springs,Meisterschaft GTC,.Totalled!
E60 M5 Dinan stg3,hiflow throttle bodies,coldair,evosport rear diff,Eisenmann Race sold
E39 M5 UUC short shift,UUC Corsa and More Sold
      07-09-2014, 09:08 PM   #9
PetrolFumes
U should get a shop foreman to do a ride along woth you...if we are bith hearing it and the cars are still oulling very hard i doubt we have anything to eorry about...i am going to have them do am engine diagnostic on the car...will keep you posted on what i hear
      07-09-2014, 09:09 PM   #10
PetrolFumes
Anyone else hearing this? Th more the better then i will think its normal
      07-10-2014, 08:18 AM   #11
M5essex
M5essex's Avatar
England
642
Drives: RR sport SVR, Vent S, 650s spi
I hear a turbo spooling sound when I boot it, which is normal to me and sounds great too
Current - 2016 McLaren 650s Spider, Aurora Blue
Current - 2016 Range Rover Sport SVR- Black
Current- 2018 Aventador S. Nereid blue
Gone - 2016 F80 CP, 2015 991 Turbo S, 2016 LCI M135i. 2015 F10 CP M5. 2015 X5, 2012 E92 CP M3. 2009 E92 335i
      07-10-2014, 09:50 AM   #12
DentalBoy
DentalBoy's Avatar
50
Thanks! Look forward to hearing outcome!
      07-10-2014, 08:01 PM   #13
PetrolFumes
Does it have a buzz to it?
      07-14-2014, 05:37 AM   #14
M5essex
M5essex's Avatar
England
642
well not so much the engine or turbo, but my centre B&O pop-up speaker gives off a buzzing sound when the engine is under load or at WOT...
      07-14-2014, 07:31 AM   #15
Spinny02
Spinny02's Avatar
Drives: '14 M5 CP Dinan Stage 2
Bad ground or loose connection ? Do you any equipment added to your car like a laser jammer, radar detector or exhaust mister. if they are not grounded properly it could do this.
      07-14-2014, 10:02 AM   #16
PetrolFumes
No nothing at all...the buzz is louder now and definitely coming from the engine bay...likely one of the turbos
      07-14-2014, 10:03 AM   #17
PetrolFumes
nope definitely from the engine
      07-23-2014, 07:57 PM   #18
PetrolFumes
I havent had a chance to bring the car in...have you had it checked out yet?
      07-27-2014, 09:57 PM   #19
PetrolFumes
      08-07-2014, 04:56 PM   #20
PetrolFumes
You still hearing it? Ever get it checked out?
      08-14-2014, 12:33 AM   #21
PetrolFumes
I find now that this buzzing only comes on around 3k rpms...once i get over 4 0r 5k rpms i just hear the turbo doing work...anyone else experiencing this?
      09-09-2014, 09:46 AM   #22
DentalBoy
DentalBoy's Avatar
50
Bmw said the noise is normal from a high performance engine and is not a concern? It does not sound normal to me, It sounds like a bad alternator or?
m5post
