02-12-2014, 04:53 AM | #1 |
European Editor
10589
Rep 22,992
F80 M3 / F82 M4 Wheel Offsets (ET) and Sizes
Ok guys... I have the info you ALL have been dying for...
Summer wheels - 9x18 (ET29) +10x18 (ET40), Style 513M - 9x19 (ET29) +10x19 (ET40), Style 437M Winter wheels - 8,5x18 (ET27) +9x18 (ET29), Style 640M - 9x19 (ET27) +9x19 (ET29), Style 641M 18" 513M on Yas Marina Blue 18" 513M on Austin Yellow 18" 513M on Mineral White 18" 513M on Black Sapphire Metallic 19" 437M 19" 437M Black Winter wheels: 640M and 641M |
10
seis-speed2430.50 natedog7700662.00 bimm3rr1.50 sabrina493.50 ZERO92250.00 AR_Motorwerkz2645.50 DELTA_24.00 FrankMstein1019.50 |
02-12-2014, 07:08 AM | #7 |
52
Rep 502
02-12-2014, 07:24 AM | #8 |
Currently Driving
269
Rep 1,426
Drives: BPM tuned '13 AW ZCP E92 M3
Will I be able to swap my ZCP wheels on the M4 and vice versa? I told my SA I want to keep my ZCP's for the M4 and they can have the M4 rims to put on my E92 when I trade. Are the lug patterns the same?
02-12-2014, 07:30 AM | #9 |
52
Rep 502
02-12-2014, 07:40 AM | #10 |
Currently Driving
269
Rep 1,426
02-12-2014, 07:50 AM | #11 | |
Moderator
7515
Rep 19,368
A positive offset is measured from the centerline of the wheel toward the outside of the wheel. So, the larger the number, the further *inward* the wheel sits. Let's compare to the style 359M from the E9x competition package, since they are the same size wheel as the 437M on the F8x. Front: 9x19 ET31 Rear: 10x19 ET25 So then, the front 359M sits just 2mm further inward than the 437M, and the rear wheel sits *15mm further outward* than the 437M. Spacers are definitely not going to help here. What we need is extra clearance from the fender lip. We'll see if that works out once someone bolts them up. I'd say there is a chance it will work, but it may need to be rolled. Of course, the other issue is that it will not have the same flushness as the front, which rolling the rear could alleviate. Or you could put a 15mm spacer in front, which is probably not a good idea. |
davem3fan185.50 |
02-12-2014, 07:52 AM | #12 |
Rep 5,396
I don't think you understand wheel offsets.
The OEM ZCP wheels vs F8x wheels are 19x9 ET 31 vs 19x9 ET 29 - -2mm for F8x 19x10 ET 25 vs 19x10 ET 40 - +15mm for F8x So basically, swapping ZCP on the new F8x would be 2mm less aggressive in the front, and 15mm more aggressive in the rear. So you could get a nice flush fitment by running ZCP and say a 12-15mm spacer in the front with no spacer in the rear. All depends on fender clearance and how the OEM wheels fit on the F8x. We will find out how much room they have once the cars are in our position and we can take some measurements.
02-12-2014, 08:38 AM | #13 | |
52
Rep 502
Sorry for confusion. |
davem3fan185.50 |
02-12-2014, 08:41 AM | #14 | |
Rep 5,396
it can certainly be done. if your point is that the offsets aren't identical between the two cars, yes that is correct. but they definitely will fit and probably will be popular with a front spacer. the good thing is that the offsets allow for a large spacer which typically fits much better and more flush on the hub. 15mm spacers are ideal in my experience. depends on fender clearance, but I bet it will fit.
02-12-2014, 08:47 AM | #15 |
Moderator
7515
Rep 19,368
Read carefully, you appear to still be confused.
Spacers will not be necessary to get offsets that meet or exceed OEM specifications. |
02-12-2014, 08:49 AM | #16 | |
Rep 4,186
Would 19x8.5 ET15 (front) and 19x9.5 ET22 (rear) wheels be flush? |
02-12-2014, 08:56 AM | #17 | |
Rep 5,396
http://www.1010tires.com/Tools/Wheel...ulator#Results first of all, I wouldn't recommend a narrower wheel like that, its important to have wider wheels that support the sidewalls fully. BMW engineers in slightly stretched wheels/tires which IMO help decrease body roll and aid in steering sharpness. so I would highly recommend at least a 9/10 inch width, especially with a 255/275 tire. that said, here are the results. fronts will be 8mm more aggressive than stock (should definitely fit and be noticeably more aggressive, but not overly aggressive. rears will be 12mm more aggressive than stock, and look about right. again, I wouldn't recommend narrower wheels, but it can be done and it will fit. its hard to say what the most aggressive fitment is, because we don't know how much more offset the car can take and still fit in the fenders. it also depends on if you will lower your car etc....
02-12-2014, 09:52 AM | #18 |
Rep 550
I am new to this, I have an 18 inch wheel setup for winter on my e92 M3. Will I be able to keep these wheels? Are spacers necessary or not? I'm not looking for deep answers, I'm a medical guy so keep it simple!! LOL
On the list for an M4!!
02-12-2014, 10:01 AM | #19 | |
Rep 5,396
use the calculator I provided in my prior post and plug in your wheels and the OEM bmw winter wheel data provided in the OP in this thread.
02-12-2014, 10:06 AM | #20 |
5276
Rep 5,378
Yup, KP nailed it.. I use that link frequently as I'm doing my due diligence on a new wheel set up.. Great tool and easy to use.
02-12-2014, 10:15 AM | #21 | |
Rep 4,318
GT3 RS | Desperately seeking the next great M car...
davem3fan185.50 |
