M5POST
      01-25-2014, 08:18 PM   #1
avlnch
Drives: 2013 Individual M5
M5 Unlocked Dash Menu
I have been using this a lot lately.
I find Tank, Temperature, Speedo/Rev, and a few others the most useful.
Can anyone elaborate on what the more complicated ones are all about, such as "Check"?
I believe "Start Roller" is what they use at the factory. At the last stage the vehicles are rolled on a dyno for a function check. It probably allows the machine to begin and turns off ESC so it doesn't interrupt the test.
I plan to look through my coding laptop soon to see if the euro value formats can be changed or not.
To Access: Hold ODO reset button down until menu appears. Just be careful that you don't accidentally get into the CBS (condition based service) area. I will attach a screenshot so you can see what is CBS and what is the unlocked dash menu.
To Navigate: Short press to move up/down. Long press to select/return to parent menu.
Unlock Code: Sum of last seven numbers in your VIN.
Example: M105510 = Unlock Code: 12
Menu Structure (Unlocked)
01 Identification
02 System Test
03 Start Roller
04 Test End
10 Unlock
11 Consumption
12 Range
13 Tank
14 Temperature
15 BC-O
16 Speedo/Rev
17 System Voltage
18 Acoustics
19 Error Codes
20 Dimming LCD
21 Dimming PWM
22 CBS
23 Check
24 Correct Factor
25 Software Reset
Here is what's shown within the above menus.
_____Identification_____
Conv Index 71441 1/mls
BTLD 06 00 00 0D 81 01 00 04
Hardware 01 00 00 0D 89 01 00 00
SWFL1 08 00 00 0D 83 01 14 00
SWFL2 08 00 00 0D 84 01 15 00
SWFL3 08 00 00 0D 85 01 07 00
SWFL4 08 00 00 0D 87 01 07 00
SWFL5 08 00 00 0D 86 01 09 00
SWFL6 07 00 00 0D 82 01 00 0A
CAFD 05 00 00 00 69 09 01 04
HWT1 02 00 00 0D 88 00 00 00
HWT2 02 00 00 01 42 00 00 00
VIN M105510
HW Index 01 00
Manufact 01.03.2013 (dd.mm.yyyy)
Company 00 00 08
StdCore 06.07.02
_____System Test_____
Start System Test ?
_____Start Roller_____
Mode (ESC OFF) ?
_____End Test_____
End Test ?
_____Unlock_____
Unlock Code 00
_____Consumption_____
Consumption Dist 17.4 l/100km
Consumption Time 0.0 l/h
_____Range_____
Range Consumpt 13.6 l/100km
Range 308 km
_____Tank_____
Tank Left 457 ohm
Tank Right 437 ohm
Tank Left 20.3 l
Tank Right 17.9 l
Tank Total 38.2 l
Display Value 41.9 l
Tank Phase 1
_____Temperature_____
O Temp Sensor 197 ADC
O Temp Raw Data +24.7 C
Coolant Temp +25 C
Oil Temp +26 C
_____BC-O_____
Liter Counter 35.5 l
Time Counter 19062 s
Distance Counter 184.9 km
_____Speedo/Rev_____
v CAN 0 km/h
v Pointer 0 km/h
Cruise Control 0 km/h
Rev Counter 0 1/min
_____System Voltage_____
System Voltage 11.8 V (engine off)
_____Acoustics_____
Acoustics ?
_____Error Codes_____
No. DTC Env1[km Env2[s] Active
01
02
03
_____Dimming LCD_____
LCD Temp Sensor 2F7 ADC
LCD Temperature +32 C
Light Sensor 053 ADC
LCD Luminance 3F
_____Dimming PWM_____
Dimming Wheel FE
Display 1527
LED Red 1527
Scales/Pt White 665
Scales Pt Orange 0
Corona 5920
Corona Closing 272
Underfloor Pointer 2507
Status Lights 2000
Status Lights Blue 0
_____CBS_____
KM/Year Short-Term 16000 km
Service Call Status 0
Limit Time 255 month
Limit Distance 51000 km
_____Check_____
No. CC-ID KM Active
01 0557 004372 0
02 0557 004385 0
03 0557 004432 0
04 0557 004498 0
05 0557 004569 0
06 0557 004618 0
07 0557 004629 0
08 0557 004641 0
09 0557 004681 0
10 0557 004681 0
*11 THRU 39 TRUNCATED*
40 0557 005413 0
40 0557 005413 0
40 0557 005413 0
40 0557 005413 0
_____Correct Factor_____
Change Factor ?
Econ Consumption 1000
_____Software Reset_____
Software Reset ?
2013 BMW INDIVIDUAL ///M5 {Frozen Black/Amaro Brown/Amaro Brown Alcantara/White Contrast Stitching/Piano Black Trim}
      01-25-2014, 08:43 PM   #2
Salespunk
Drives: Slow
So will this allow setting the seat coolers lower etc or is that a different menu?
      01-25-2014, 09:46 PM   #3
avlnch
Where did you get that from? Maybe you are confused between the unlocked dash menu and coding?
The hidden/unlocked dash menu is basically for showing advanced informational data.. like exact temperature of oil and coolant, exact amount of gas in the tanks, and etc info as shown above.
There is also something called coding where you can "code" different modules in the M5. If you want to make the ventilated seats more effective, that is something that can be coded - however this is unrelated to the hidden dash menu. There are tons of other modules and features that can be coded.. like showing tire pressure and temp, folding mirrors when car is locked, and many many others. I have a PDF of features that can be coded and what modules they are within. It can be found in the navigation/iDrive/audio fourm as a sticky named M5 Coding List.
      01-26-2014, 06:26 AM   #4
mstmng
United Kingdom
141
Drives: M5 F10
very interesting info Avlnch
will try to access it today
do you think there is a way to change oil changes intervals in CBS through this settings or it needs to be coded?
cause as we know LCI's m5 have their oil change intervals shortened by half, i would love to have it in my car as well
as i have service pack and don't see a point paying for mid-cycle oil changes myself, when exact same engine in exact same car with new lights and new steering wheel gets it for free!
i spoke to my technician from bmw, he said he will talk to main M technician, but he is a bit of a c***, took my technician to convince main M tech to change my suspension (due to known clunking noise) 3 weeks!
so i doubt they will reprogram my CBS ! but there should be a way to trick them
      01-27-2014, 04:40 AM   #5
M5NI
Drives: M5 F10
Not sure that LCI's have oil change interval shortened?. Got mine a fortnight ago and its saying oil change in 18,000 miles?
      01-27-2014, 07:10 AM   #6
Spinny02
Spinny02's Avatar
Drives: '14 M5 CP Dinan Stage 2
Very neat. I am curious about the roller menu.
Who can confirm what this is for???
      01-27-2014, 09:42 AM   #7
avlnch
That's what I think.
      01-27-2014, 10:50 AM   #8
Spinny02
Spinny02's Avatar
So i would assume we could use this if we dyno now for better results due to open hood, front tires not rolling ect>?
      01-27-2014, 12:06 PM   #9
avlnch
I have a feeling it's only meant to work when it's plugged into the BMW factory computer/dyno.
When you start it, no light or indicators appear. But, it's worth a try next time you dyno your M5.
It would be nice if it were some special ECU mode for when on a dyno.
m5post
