      12-05-2013, 10:29 AM   #1
crystaweizen
crystaweizen's Avatar
Drives: Alpine White '08 135i
2008 BMW 135i  [10.00]
Anyone replace leaking oil cooler to housing seals?
anyone had to replace the seal that goes between the oil cooler and the oil filter housing? and im not talking about the between the housing and block, ive already replaced that one. it looks easy enough to do, im not exactly sure if I have to remove the two hex plugs at the top to take the line down to access the third bolt of the oil cooler? was just wondering if this challenged anyone, it looks a lot simpler than the oil filter housing gasket
      12-05-2013, 03:10 PM   #2
c0ris07
c0ris07's Avatar
Australia
25
Drives: BMW 135i
No you do not need to take out the top hex bolts. Just the third from the underside and the lines will come free. Each line has an o ring on it it if that's what you are looking to replace.
      12-05-2013, 05:05 PM   #3
crystaweizen
nope just the gasket/ seal between the cooler and the filter housing. was it pretty easy??
      12-05-2013, 06:43 PM   #4
c0ris07
c0ris07's Avatar
Australia
25
Drives: BMW 135i
So you are replacing part 5 gasket below? I have not replaced that, I just took the lines off to put an ER sports cooler on.
To go back to the original question, you just remove the third bolt from below that sits between the lines then they pop off. Then you should be able to get to your third bolt.
Just make sure you have rags handy.
1addicts
