M5POST
      11-03-2013, 12:16 AM   #1
Sejzilla
Sejzilla's Avatar
South Korea
49
Drives: AW 14 M5 ZCP
Squeaky noise from suspension?
I picked up a 2014 M5 with Comp pkg and I feel llike I hear Squeaky noise coming from the suspension when going over bumps or uneven rroads... Anyone else experiencethis?
AW 2014 M5 ZCP | SG 2013 GL550
AW 2009 M3 (sold) | AW 2011 535xi (sold) | AW 2011 M3 6MT (sold) | OB 2009 GT-R (sold) | AW 2008 335i 6Speed (sold)
      11-03-2013, 06:44 AM   #2
bobblehead
bobblehead's Avatar
Drives: warp speed
on my 13, yup! It comes and goes and not consistent to weather, temp, etc. I think it's the sway bar bushing. Dealer cannot isolate and duplicate the issues. I ask the dealer to lubricate it and they said it cannot be done, unless the whole thing is replaced under warranty. But since it can come and go without normal frequency, nothing was done at all to address my issue.
      11-03-2013, 08:29 PM   #3
Sejzilla
Sejzilla's Avatar
South Korea
49
I was thinking about bringing it to the dealer also but had a feeling that they were gonna pull out their normal "can't duplicate" bs on me so i didnt bother... anyone had this problem fixed?
      11-06-2013, 06:19 AM   #4
msi200
Bulgaria
19
Drives: M2
I have something similar on my '13 but I think it is related to the brakes. It can be heard only with open windows and it goes away if the brakes are applied even slightly.
      11-06-2013, 09:56 AM   #5
thebishman
Drives: ‘24 iX M60
Could be a floating rotor issue as noted above which is completely normal.
Bish
      11-06-2013, 03:59 PM   #6
Lual
Drives: M5 2014 CP / X5 G05 ‘21
I have the same problem, on both sides. Also in a CP.
Normally when driving over "covers of water drain / canalisation" (no idea about the proper english term).
Noise is pretty annoying in a +100k car.
Will ask to check in break in service.
      11-14-2013, 02:06 PM   #7
chong0
Drives: '16 X5 5.0
I think Bish is right it's probably rotor related.
I had no squeak prior to my HPDE and roasted the brakes. After replacing everything, I now have the squeak.
'22 Macan GTS
'21 911 C2S
'20 Cayenne
'16 X5 50i M-sport (3rd row!)
      01-05-2014, 10:41 AM   #8
Patrys@BimmerTech
Poland
620
Drives: 2007 E92 335i
If you can hear a noise at the back when going over bumps your springs might need to be replaced. It is a common issue for the M5.
You can put some stuff in the trunk and some friends on the rear seat and if the noise goes away these should be faulty springs.
      02-07-2014, 11:01 AM   #9
X5Blair
Drives: X535d; M2, M3, M5, 540d, AMV8V
I have the same issue, it's been ongoing since about Feb 2013. At that time very intermittent. Over the past few months its pretty much non-stop. Took it in today and they had no problem hearing it. Said it was the sway bar bushings in the front although I hear it front and rear. They said they lubricated them and that this would solve the problem. It does give me some concern though since I hear others saying that there was no fix...
      08-03-2014, 03:25 AM   #10
TheX6M
Drives: X6M 2010 , 1M and now M5 2013
Had same problem in my 2013 m5 , went to dealer in Dubai they did some lubrication for the front one and the sound went away . The back noise they order some part for me and they just arrived dropped the car , will check the result as soon as i collect the Car and will advice what parts has been replaced exactly .
m5post
