M5POST
      10-16-2013, 08:21 PM   #1
dhirm5
Drives: 2014 M5 ZCP, 2014 X5 35d
USB connection "flapping"
Picked up my F10 CP this evening - pix to come tomorrow once the sun comes back out. Pickup was in the late evening.
First problem encountered - when I plug my iPhone 5s in via the USB to lightning cable, it connects and disconnects rapidly on the phone - i.e. the phone makes sounds as if the plug is being connected and disconnected rapidly - and the icons at the top of the screen indicate the same.
The same cable works fine to connect to my computer, so it's not the cable.
Anyone seen this? I assume there's something wrong with the USB jack.
      10-16-2013, 10:52 PM   #2
boots
Curve Thrasher
boots's Avatar
623
Drives: 2013 Bmw m5..White/Blk.
Mine does that every now and then. But I think it is my cord. It goes away after I reposition the cord.
      10-17-2013, 06:46 AM   #3
dhirm5
Yep - turned out to be the cord. I tried my actual Apple supplied cable and it worked fine.
      10-17-2013, 11:35 AM   #4
savela
savela's Avatar
Drives: 2015 X5M
there have been a bunch of reported problems with aftermarket 'lightning' cords - not necessarily specific to bmw but their quality in general. i would stick to apple. even the ones on amazon that are sold as oem have been questionable.
2015 ///X5M
2014 ///M6 (traded)
2014 ///M5 (traded)
2011 550i (traded)
      10-17-2013, 01:16 PM   #5
rjn21
Drives: 2014 M5 LCI
SI B84 06 13
situation
When using the USB cable to connect the iPhone to the USB audio interface, the iPhone charging status constantly switches between charging and not charging. This is noticeable by the alternating flash in the battery symbol on the iPhone display.
cause
The quality of the USB cable can cause a voltage drop (usually caused by using aftermarket cables).
information
Do not replace any other parts!
Advise the customer that he/she must use one of the following:
The original Apple iPhone/iPOD USB cable that came with the device
A BMW supplied iPhone/iPOD USB adapter cable
parts information
Part Number Description Quantity
61 12 2 220 019 USB Adapter for Apple iPhone/iPOD (Reference only) 1
      10-17-2013, 09:47 PM   #6
boots
Curve Thrasher
boots's Avatar
623
Mine is original cord but as stated wear and tear can cause it.
      10-22-2013, 11:49 PM   #7
greentrbo95gst
greentrbo95gst's Avatar
1231
Drives: 21 M5 Comp
I used a brand new apple cable for the ipod and it worked for a while. It just started to get loose again and it keeps on disconnecting. It's annoying.
Current: 21 M5 Comp, 17 X5M, 06 M3, 14 Ferrari FF, Tesla Model S Performance.
m5post
