10-07-2013, 04:13 PM | #1 |
Rep 39
Can I lower the clutch on my 128i?
I want to know if I can lower the clutch on my 128i. I am 6'3", and it would be much better for me if the friction point was a couple inches lower - flush with the brake pedal would be ideal. I did this on my 98 prelude years ago, and it made a great difference. I already have my seat all the way back, and I could use the extra space if possible!
thanks |
10-08-2013, 07:02 PM | #2 |
Just one more taste...
566
Rep 2,011
Hp autoworks has an aftermarket clutch pedal but it's pretty costly.
My Build Thread: Jet Black 6MT 128i with MSport
10-08-2013, 08:12 PM | #4 |
European Editor
10628
Rep 22,992
Maybe your clutch is worn out ? When its new the engagement point will be lower than with lots of miles/and wear, it will be higher up the pedal travel point.
Have you been in another (new-er) manual 128i ?
10-09-2013, 01:17 PM | #5 | |
Rep 39
When you say the engagement point will be higher up - do you also mean it will be larger? Obviously, I'm not looking to expand this friction point - only "re-locate" it. FYI - this is what I did with my old car. I've heard that it may not be possible on the Bimmer, but wanted to find out for sure. |
10-09-2013, 01:20 PM | #6 |
Rep 39
10-09-2013, 01:46 PM | #7 |
566
Rep 2,011
10-09-2013, 02:59 PM | #8 | |
Rep 39
10-09-2013, 04:54 PM | #9 | ||
European Editor
10628
Rep 22,992
BUT when the clutch is new... this point that the clutch starts to engage will be towards the bottom of the pedal travel. Typically just off the floor/carpet. As years and miles go by... (sometimes a 1/4 mile at a time!) the clutch's engagement point will become higher and higher up the pedal. First in the middle of the clutch pedal stroke and then finally towards the top of the pedal stroke. Thats when you know your clutch is on its last legs. That and maybe clutch "chatter" vibrations as you let the clutch out(engagement). Quote:
G.L. Dackel
11-03-2013, 08:12 PM | #10 |
Former E46Fanatic
13
Rep 284
I had this on my E46. AMAZING!
Current Cars: 1987 E30 325is
1991 E30 325i 1991 E31 850i 2018 G01 X3 2004 B15 Sentra SE-R (daily) |
