XBimmers.com | BMW X6 Forum X5 Forum
TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > X5 Vendors Classifieds
      05-14-2013, 02:31 PM   #1
ECSTuning
New Lifetime Replacement Policy
ECSTuning's Avatar
818
Drives: Independent Tuning Specialists
:: ECS Tuning :: N62 Collapsible Water Pipe Kit|Ingenious? You Bet!
Here's an uncommonly creative solution to a common problem.
Eliminate the notorious water pump transfer pipe leak on N62 4.4 and 4.8L engines with a collapsible pipe kit that saves hours of teardown. If you've been avoiding this job because you didn't want to go through the hassle and expense of pulling the heads and timing cover, this kit is the answer.
Just pull the intake and valley pan and cut out the old pipe. Then insert and expand the collapsible pipe in a fraction of the time.
This complete repair solution includes seals and lube for a leak-free repair.
Click HERE to order today
      05-29-2013, 09:52 AM   #2
ECSTuning
ECSTuning's Avatar
818
It's the easy pipe
      06-10-2013, 03:13 PM   #3
ECSTuning
ECSTuning's Avatar
818
      05-28-2014, 03:37 PM   #4
ECSTuning
ECSTuning's Avatar
818
Click HERE for your 745i (2002-2006) Collapsible Water Pipe Kit
-water pipe only-
Click HERE for your 745i (2002-2006) Water Pipe Service Kit
-includes every thing needed for a basic water pipe replacement-
Click HERE for your 745i (2002-2006) Advanced Water Pipe Service Kit
-More advanced service kit with Graf water pump with metal impeller-
Click HERE for your 745Li (2002-2006) Collapsible Water Pipe Kit
-water pipe only-
Click HERE for your 745Li (2002-2006) Water Pipe Service Kit
Click HERE for your 745Li (2002-2006) Advanced Water Pipe Service Kit
Click HERE for your 750i (2002-2006) Collapsible Water Pipe Kit
-water pipe only-
Click HERE for your 750i (2002-2006) Water Pipe Service Kit
Click HERE for your 750i (2002-2006) Advanced Water Pipe Service Kit
Click HERE for your 750Li (2002-2006) Collapsible Water Pipe Kit
-water pipe only-
Click HERE for your 750Li (2002-2006) Water Pipe Service Kit
Click HERE for your 750Li (2002-2006) Advanced Water Pipe Service Kit
      03-25-2015, 12:41 PM   #5
ECSTuning
ECSTuning's Avatar
818
Click HERE for your E65/E66 745i Collapsible Water Pipe Kits
      12-04-2017, 10:52 AM   #6
ECSTuning
ECSTuning's Avatar
818
Fix your water pipe the easy way with URO.
-James
Tags
coolant transfer, n62, pipe, valley pan, water pipe
xbimmers
