04-20-2013, 07:02 PM | #1 |
Rep 377
ZHP shift knob
I recently ordered this knob from tischer. My car has the shift knob with the aluminum trim that comes standard on the 128i.
I've read in places that all you have to do is firmly pull the old knob out and give the new knob a good whack into place. Some say I have to remove the boot, then remove the knob from the boot. I've also read that I may need a new boot entirely. Of course, I really would prefer not having to buy another boot. So my question is, with my car, which case is it?. |
04-20-2013, 07:09 PM | #2 |
Rep 4,531
It is my understanding that only the M-Package shift knob is attached to the boot, all other else is separate.
For my Z, I put the knob in 6th gear, and got on the passenger side. I threw on my helmet (you'll see why) and pulled extremely hard. The knob ended up knocking me in the face, which I am quite thankful I had my helmet on, as weird as it looks. Boot is separate, if I am right, so all you need to do is throw on the new knob. I love mine in the Z: |
04-21-2013, 12:46 PM | #3 |
Big Mouth No Filter
49
Rep 586
Mine was connected to the boot. I undid the boot ring (compressing from the sides) and then straddled the frame tunnel and pulled with all my might. The knob let loose of the shaft and the boot came up with it, along with the trim ring. Had I not removed the trim tring first, I am sure that pulling the knob off would have ended up ripping the boot.
Removing the trim ring from the console 1 minute Straddling the tunnel, pulling the knob off 1 minute Removing the old boot and tacking the new knob in place 3 minutes Redoing it; the knob wasn't facing in the right direction when installed 2 minutes Reattaching the boot trim ring to the console 1 minute Total time including screwup 10 minutes or less. A forum member now has my 'stock' knob...
We do not inherit the Earth from our parents; we borrow it from our children
04-21-2013, 01:29 PM | #4 |
Rep 1,198
My boot was connected to the knob and I have a non m sport 135. Your 128s will be connected too. Unsnap the boot from the center console first then pull the knob off. It will all come off together then there's a little metal retainer ring attaching the boot to the knob. Remove that and the knob will fall off an ur free o reuse the boot. I left mine connected as I bought an alcantera boot to go with my new knob
2013 BMW 135i Alpine white/coral red JB4 stage 2/ AFE stage 2 sealed intake box/ VRSF 3.5 inch catless dp/ Dinan exhaust/ Alpine V3 6000k HID angel eyes/ JB speed AW rear lip spoiler/ OEM mud flaps. ER charge pipe/ VRSF 7 inch FMIC forge star CF5s 19x8.5 and 19x9 |
04-22-2013, 07:35 PM | #5 |
Rep 377
The knob comes tomorrow, hopefully. I was ready ready to rip my boot trying to just remove the knob had it not been for you two. Thanks for the replies everyone!
12-11-2013, 07:11 AM | #8 |
Rep 4,531
12-11-2013, 08:29 AM | #9 |
Resident Tamed Racing Driver
298
Rep 4,697
I've always been amused over the debates on the best way to remove the knob.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
12-11-2013, 11:20 AM | #10 |
Rep 2,239
Stock knob is attached to the boot by a few little pins. Bend them and separate the boot from the knob. I have the ZHP knob on and just pressed it on with the boot just loosely on. The new knob just squeezes the boot between it and the top of the shift lever.
The first time i removed the knob I also punched myself in the face
08 e93 335i MT
12-27-2013, 08:14 AM | #11 |
298
Rep 4,697
It gets more fascinating if you retrofit the M5 illuminated ZHP knob and need to transfer the boot from the stock shifter to the M5 knob. I ended up using 2 stage epoxy which worked perfectly.
01-11-2014, 07:02 AM | #12 |
Rep 1,491
damn that looks great!
Black Wrapped Roof, BFG Rivals, Dinan Camber plates, M3 Steering wheel, Matte Black kidney Grills, H&R Sport springs,
Sparco assetto gara,Pagid sport Brakepads,STOPTECH Slotted Rotors, DISA STG3,EURO BOX |
Tags |
boot, knob, shift, zhp |
