M5POST
      03-28-2013, 04:31 PM   #1
johntomferg
Drives: Formerly drove a 13 F10 M5
Anything stickier?
Just curious if anyone has found any stickier tires than the Michelin Pilot Super Sports for the stock 20" rims?
      03-28-2013, 06:38 PM   #2
thebishman
Drives: ‘24 iX M60
As far as a tyre that is an ultra high performance street tyre I doubt you'll find a better one than the PSS.
Bish
      03-28-2013, 06:39 PM   #3
PatrickC23
PatrickC23's Avatar
Drives: '16 991.1 911 GTS, '16 F85 X5M
2013 BMW ///M5  [0.00]
I cant wait to drive on PSS tires. I havent heard anything bad about them.
      03-28-2013, 07:37 PM   #4
Poleposition
Poleposition's Avatar
Drives: very well
Bish
Agreed.
2022 Individual M5 Comp
Venetian Violet
2021 X6M Comp
2024 i4 M50 on order
IG @purpleM5Comp_NY
      03-28-2013, 07:49 PM   #5
URBAN LEGEND
Rocky
URBAN LEGEND's Avatar
Drives: 16 M5, 18 ZL1 1LE, 18 M3
Stickier for the drag strip? Street?
      03-28-2013, 07:52 PM   #6
johntomferg
Street - Summer - Dry.
      03-28-2013, 09:32 PM   #7
stealth.pilot
Knight Commander
stealth.pilot's Avatar
United Kingdom
559
Drives: 2014 911 Turbo S
In the OEM size the PSS is the best tire you can get. In fact it is the best street tire available period.
However, you can get Pirelli P Zero in 275/35/20 and 305/30/20
It's not obvious to me whether the grip advantage of wider tires will offset the inferior tire. It's an interesting thought though.
Also I don't know if you could go even wider to 285 and 315.
Any thoughts?
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray
      03-28-2013, 10:21 PM   #8
jmh
Internet Crash Test Dummy
jmh's Avatar
Drives: F97 X3MC / F80 M3 / F90 M5
Any thoughts?
I have the Pzero in 305 (widest you can go without rubbing/modifications) and I can tell you it is noticeable less "sticky" than the PSS
Just on slight acceleration the Pzero will cause traction control to go on (especially around corners) where the PSS didn't break loose at all.
However all of my experience so far has been in temperatures in the 40s at best so take it with a grain of salt. As temps warm up I should have more data points to sample from.
If the PSS would be available in 305 I'd absolutely have gone for them.
21 F97 X3MC Toronto Red/Black and more | 18 F80 M3 Tanzanite Blue/Amaro/CCB and more
15 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / IND / Akrapovic Evolution Exhaust / HRE S107
      03-29-2013, 04:19 AM   #9
johntomferg
Thanks guys.
Pretty sure 315 will not fit the current stock wheel.
Interesting feedback on the Pzeros.
Jan, Stealth, et al,
With the stock tires the odd thing I am finding right now is that as things warm up here and move into the 50-60 (F) range is that the tires are slipping more than they were when it was in the 40-50 (F) range.
Now, granted, this is very unscientific and not "at the limit testing" but it is my general observation for "spirited driving". From a speculation standpoint here are some ideas I have about it, but I can only speculate and see if I can rule any out as time progresses:
1) There may be critical temp range (50-60 F?) where there is actually a dip in traction and traction increases again when temperatures get back into the 70, 80, 90+ range. [How to try validating: I can try to observe further as temperatures increase, but we have had several cycles where I get to experience the 50-60 F range and then it colder again. I think we are done with thart now ad will seee steady temp increases going forward]
2) Driving in sub 50 degree temps may allow "oil soak" into the tire from the road and parking surfaces and the increase in temps is allowing the tires to 'expel' that oil thus giving lower traction. [How to try validating: same test case as 1]
3) Similar to 2, roads warming are allowing the winter "oil soak" to surface at this temp range. [How to try validating: Need a warm/hot hard rain and then drive afterward on the same stretch of asphalt that was driven previously.]
Other comments:
I can tell you that I can see the black staining from the tires on the garage floor much more than any other vehicle I currently or have previously owned. But, that is likely contributed to by the large amount of brake dust generated by the car.
The "suction cup" effect I was getting when I would pull away after the car had been parked in the garage has all but gone away. It was most prominent after I took re-delivery in Dec/Jan.
If you guys can think of other possibilities, I would like to consider them.
Are any of my experiences above similar to other members?
      03-29-2013, 06:39 AM   #10
PatrickC23
PatrickC23's Avatar
My C63 came with PZeros, now I've never had PSS tires, but I can attest that the PZeros are extremely soft and don't last long at all. The biggest complaint on the boards there were about members burning through the rears in 3-4k miles. Now this was mostly blamed on the torque of the C63, but the M5 has 25% more torque than that car.
      03-29-2013, 07:26 AM   #11
stealth.pilot
Knight Commander
United Kingdom
559
I find my traction is very good. I am driving in South Florida so ambient temperatures have been in the 70s through the winter.
I do find the tires need to get some heat to optimize traction even in this climate.
      03-29-2013, 09:28 PM   #12
GhanemMBN
GhanemMBN's Avatar
United Arab Emirates
35
Drives: MB SLS AMG & BMW X5M
Pirelli Corsa
      03-29-2013, 09:52 PM   #13
Charlie Brown
Charlie Brown's Avatar
Drives: F10 M5 Azurite Black
I'm also looking for a sticky tire for the drag strip to fit the stock 20" or 19" rim. Ideas?
      03-30-2013, 07:58 AM   #14
johntomferg
Originally Posted by GhanemMBN View Post
Pirelli Corsa
Treadwear:
60 AA A
      03-30-2013, 01:06 PM   #15
thebishman
Drives: ‘24 iX M60
Check TireRack.com to see if there is an Hoosier A6 or R6 that would fit the 19" rear wheels. Just remember you couldn't drive them to the track, you'd have to change wheels there.
Bish
      04-01-2013, 09:55 AM   #16
richb811
richb811's Avatar
465
Drives: 2020 G20 330i M Sport
Originally Posted by johntomferg View Post
Treadwear:
60 AA A
Yeah, you'd have to switch those out after pulling out of the driveway.
      04-01-2013, 12:02 PM   #17
mcvaughan
mcvaughan's Avatar
Drives: F87 Competition
Don't think there's fitment options for the 20s, but believe you can get close in the 19in variant of the Michelin Pilot Sport Cup. I used them on my Porsche track weapon a few years back. They're sticky and you can drive on US roads with them. Only other concern that I can think of is the weight rating. I'm sure Tire Rack has someone there who can help you with this...
Matt
m5post
