      01-31-2013, 09:56 AM   #1
RedMMMeR
RedMMMeR's Avatar
Drives: 2011 e92 M3 6MT
HELP! My headlights are malfunctioning
i recently bought led angel eye bulbs.i try one side and turned the lights on. I then found it wasnt a color that i liked so i took it off. Later that night i go for a drive and i see that my right side headlight isnt functioning. do you think i blew a fuse or burned my headlights out? please help me
      01-31-2013, 09:59 AM   #2
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
More info what is not working?
      01-31-2013, 10:02 AM   #3
RedMMMeR
RedMMMeR's Avatar
the hid on the opposite side isnt working.the angel eye works just not the hid. the main headlight
      01-31-2013, 10:03 AM   #4
RedMMMeR
RedMMMeR's Avatar
the amber corner also works.the only part not woking is the main hid headlight
      02-01-2013, 03:40 AM   #5
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
Check the bulb
      02-01-2013, 07:16 AM   #6
RedMMMeR
RedMMMeR's Avatar
how would i be able to tell if its the bulb? by putting in a new one or can you tell if the bulb is any good
      02-01-2013, 11:56 AM   #7
135i OREO
Germany
28
Drives: 2009 BMW 135i
2009 BMW 135i  [0.00]
Did you get any kind of warning on the dash about your headlight not working?
2009 BSM 135i 6MT
      02-01-2013, 01:03 PM   #8
cheshirecat79
cheshirecat79's Avatar
Drives: 370z & 135i
Not enough details in the first post.
OP, double-check that the bulb is seated properly. Also double-check your wiring. Sounds like you missed a plug. I'd be surprised if there's not a dash warning.
      02-02-2013, 06:22 AM   #9
RedMMMeR
RedMMMeR's Avatar
yes i have the dash warning
      02-02-2013, 12:44 PM   #10
pvtdonuts
Drives: '09 135i
It might be a plug as others have mentioned. I installed LED's for my halos and the dash light came on because the resistors were getting in the way of the adaptive motors, might wanna check that out too.
      02-02-2013, 04:28 PM   #11
b1aze
Just one more taste...
b1aze's Avatar
Drives: 2013 128i 6MT MSport
Mine throws the AHL malfunction code randomly. Im not sure if its the heat sink/inline capacitor thats moving and getting in the way or if some moisture got into the back of the headlight assembly and it shorts out occasionally. It seems like the code doesnt get thrown easily when its really cold out, but once the car (and presumably the back of the headlamps) warm up, i would get the code daily. Now the past 3 days i havnt got the code once. Once it gets a little warmer/dryer out, ill likely drop the front bumper off, remove the whole headlight assembly and properly secure the leads off to the side. Until then, i get a very intermittent AHL fault.
Tags
headlight, problem
1addicts
