12-15-2012, 12:55 PM | #1 |
Rep 858
Excessive Camber with H&R Springs
sorry, dont have a pic, but will post one.
Got my car back from getting H&R installed. Height is great but the camber is WAY excessive in my opinion - especially the front. Can someone else with H&R take a picture from the front of the car showing the camber? I'll be putting 21's on soon and I really done want the lowered Civic look. thanks ! |
12-15-2012, 01:10 PM | #2 | |
Rep 565
MindlessMark07 ///2013 M5 Alpine White/Black,Orange County CA\\\ |
12-15-2012, 03:36 PM | #3 | |
Rep 1,548
CURRENT:
His: Porsche 991 Turbo S Carrera white/Black Hers: BMW X3MC BSM/Black |
12-15-2012, 05:08 PM | #4 |
Rep 43
+1. You should always get your alignment checked out when lowering the car. Preferably go to a shop that understands and has worked on performance cars instead of those national chain stores that get people in and out in a flash. Equally important besides checking the camber is making sure the toe is correct (an excessive amount will result in scrubbing tire life a lot faster).
12-15-2012, 05:19 PM | #5 |
Rep 1,314
I always thought it was a rule of thumb to get an alignment after lowering. I was curious about lowering mine with H&R's...but ride quality is important and due to "only so much" you can adjust camber after lowering it persuaded me not to. Not only do I dislike compromised ride quality, but I hate front tire noise from poor camber.
12-15-2012, 05:50 PM | #7 | |
Rep 858
12-15-2012, 06:02 PM | #8 | ||
Rep 1,548
CURRENT:
12-15-2012, 07:48 PM | #9 | |
Rep 43
Manufacturer cars have a leeway on alignment adjustment with tolerance range so unless you're lowering the vehicle considerably (i.e. slammed on coilovers) the car's OEM components should be able to compensate for the subtle lowered height of the H&R springs. If the camber concerns you to the point of worry, take it back and have them readjust to your liking. I'm sure they can set it to your liking that's still within tolerance. |
12-15-2012, 08:07 PM | #10 |
Rep 565
Also, does changing springs void your warranty? I know that technically as long as any issues that require repair would be covered as long as the modification didn't cause it, but in the real world, would the dealership just see the springs and cancel the warranty?
12-15-2012, 08:53 PM | #11 |
Rep 1,758
Drives: 30Jahre M5 plus a few more M's
Garage List 2022 BMW M5 CS [0.00]
2020 BMW M340i Xdrive [0.00] 2019 BMW M2 Competi ... [0.00] 2003 BMW DINAN S3 M5 [0.00] 2017 BMW 30 Jahre M3 [0.00] 2016 BMW M4 GTS [0.00] 2015 BMW 30 Jahre M5 [0.00] 1995 BMW M3 [0.00] |
No excessive camber effect at all. I was told to wait 2 weeks for the alignment. Getting spacers then alignment on wed.
I have side view pics in another thread so can't see camber. Looks close to stock camber to me?
Current non-BMW's
20 Jeep Grand Cherokee 03 Cooper S (Maxi Tuned 50bhp) 60 Impala (43k orig mi) 15 Turbo S (Kobb tune and Kline exhaust) |
12-15-2012, 09:14 PM | #12 | |
Rep 995
The dealer will likely deny any suspension claims because of the aftermarket springs. This happened to me on my old M3.
Can someone post pics of the front and rear cambers with h&r springs? Quote:
12-17-2012, 10:44 AM | #13 |
Rep 10,167
I did my alignment 2 days after the H&R install.... no visual camber concerns prior or after. The drop is minor guys, 1 inch in the front and 6/10ths in the rear... it should not create much of an issue. And the alignment will rectify.
And in reality a little negative camber is fine for those who drive the corners alot. To avoid real tire wear the toe is the measurement that needs to be spot on.
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black Last edited by Vic55; 12-17-2012 at 11:01 AM.. |
12-17-2012, 10:53 AM | #14 | |
Rep 565
12-17-2012, 11:03 AM | #15 |
Rep 10,167
Mark you can get an alignment done for 100 bucks at WheelWarehouse down the road from EAS. They did mine and I find no travel at lower or higher speeds and the car is as planted as ever at 160 mph and 16 mph LOL
12-17-2012, 11:14 AM | #16 | |
Rep 565
12-24-2012, 12:43 PM | #17 |
Rep 1,758
My alignment was barely out after the springs :-)
Happy as ever
Current non-BMW's
12-24-2012, 01:01 PM | #18 |
Rep 565
I had EAS do an alignment while the car was with them. The alignment plus the spacers make it look that the car was delivered from the factory that way. Just do it. Don't fear the drop.
12-24-2012, 01:14 PM | #19 |
Rep 1,758
Exactly, (and with larger exhaust tips)
Current non-BMW's
12-25-2012, 10:29 PM | #20 |
Rep 639
Drives: 2014 Porsche 911 Turbo S
No camber issues either.
CPIGUY 2017 Ferrari 488 Spider 2019 Tesla Model 3 Performance 2019 BMW X5 MSport, in coming |
07-18-2013, 06:42 PM | #21 | |
Rep 602
any ideas what the specs on camber and toe should be? thanks.
e92 m3 6MT, RS4 6MT, S4 Avant 6MT, WRX 5MT, Corsica
07-19-2013, 09:56 AM | #22 |
Rep 10,167
I would need to check my latest alignment sheet. I cant "supposedly" get my car aligned at the dealer because I have aftermarket wheels and their rack needs the factory wheels with those holes around the hubs I guess.
I use a local shop that is well known and I think they paid for the 2013 chassis info... I know I have the M6 numbers.
