09-27-2012, 05:55 PM | #1 |
Supreme Allied Commander
3867
Rep 54,426
Drives: F80 M3
Macht Schnell Competition Wheel Spacer Kit for your 1M
Machined from 6061-T6 aerospace aluminum, these adapters are strong as well as lightweight to limit unsprung/reciprocating weight for maximum performance on or off the track. Spacer edges are also chamfered to allow for easy installation/removal if needed. After machining, the spacers are then anodized for additional strength, anti-corrosion & wear resistance.
A wider track stance increases lateral stability as well as giving your BMW a much more aggressive appearance after installation. Spacers also are used to correct wheel gap normally seen on otherwise stock suspension setups, pushing the wheels outward - filling the fenders. Included with our Competition Wheel Spacer Kits are a full set of extended lug bolts. All wheel fasteners are hardened and tempered to strength class 10.9 or 10 according to DIN/ISO standard 898 and meet the statutory requirements of all countries - including the US. Competition Wheel Spacer kit Features: - Machined from 6061-T6 aerospace aluminum - Chamfered edges allows installation & removal quick and easy - Black anodized finish for additional strength and corrosion/wear resistance - Improve handling by reducing body roll with a wider wheel base - Included zinc plated corrosion-resistant wheel fasteners Competition Wheel Spacer kit Contents: - (2) Competition Wheel Spacers - (10) extended-length zinc plated coated wheel fasteners Models Supported: 2008+ E82/8 1-Series & 1M 1992+ E36, E46 & E9X 3-Series & M3 2004+ E60/1 5-Series & M5 2005-2010 E63 6-Series & M6 1996-2002 E36 Z3 & Z3M 2003+ E85 & E89 Z4 & Z4M Available in 3, 5, 10, 12, 15, 18 and 20mm sizes. All spacer sizes are in stock! Price starts at $49 Order here: http://www.hpashop.com/Macht-Schnell...pacers-bmw.htm Don't forget a none marring deep 17mm socket to protect your wheels: https://www.amazon.com/gp/product/B0...c05e34ca659a32 Last edited by HP Autosport; 08-12-2019 at 11:01 PM.. |
07-26-2013, 12:24 PM | #3 |
3867
Rep 54,426
Drives: F80 M3
