M5POST
      09-06-2012, 06:42 PM   #1
Niko1414
Drives: 720S, s550, S7, 997GT3RS
Brakes Squeaking...oh my
Have about 650 miles on the new ride and the front brakes are squeaking. only when they are warmed up, nothing when cold. This has happened from day one but squeaking seems to be getting worse lately. no hard stops. Anyone else ?
      09-06-2012, 07:03 PM   #2
Bmill
E39, E60 and now F10
Bmill's Avatar
12
Drives: F10 M5 Thriple Black
Did your car sit outside like mine on the dock for 87 days?
I have plenty of rust and squeaking!
      09-07-2012, 02:15 AM   #3
Niko1414
Mine sat only for two weeks, so no rust.
      09-10-2012, 03:47 AM   #4
singularity
Driver
singularity's Avatar
94
Drives: M5 (F10)
Yes, there are others. Sometimes after driving for a couple of hours my brakes squeak and whine like an old bus coming to a stop.
http://f10.m5post.com/forums/showthread.php?t=688447
      09-10-2012, 09:31 AM   #5
blackjack7779
Drives: M5 F10
Yea! It happen when the brakes are hot. I was thinkin about changeing for ceramic brakes if possible?
      09-10-2012, 12:30 PM   #6
jphughan
jphughan's Avatar
Drives: '16 Cayman GT4
If the M5 is like virtually every other performance car (including the M3), squeaking brakes are normal depending on ambient temperature, brake temperature, and how hard you're applying the brakes. Ceramics will make even more noise under road use, fyi.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten:
'11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015)
      09-10-2012, 04:09 PM   #7
Niko1414
Never had this issue with my E60 M5.
      11-15-2012, 10:25 AM   #8
koxal
koxal's Avatar
Drives: 2015 LBB F85 X5M
2015 BMW X5M  [0.00]
2010 BMW M3  [0.00]
2013 BMW M5  [0.00]
Is there a solution for this?? I have 800 miles on the clock and just noticed the noise this morning in nyc trafic...
Does it go away? Any solutions?
      11-23-2012, 06:28 PM   #9
boots
Curve Thrasher
boots's Avatar
623
Drives: 2013 Bmw m5..White/Blk.
I don't have my m5 yet, but on my 550. when it rains, mine squeak just slowly moving forward inch by inch. I cant stand it. My SA told me it was because I had aftermarket wheels. I looked at him and laughed. I hope this problem can be fixed with all the money spent on these cars. My 07 yukon has 150k on the clock and has never once had a brake problem.
      11-23-2012, 07:05 PM   #10
deathray
Drives: F85 X5M, iX 50, Range Rover
Ive seen brake squeak appear on my old x5 due to excessively light braking over a long period of time (i.e. an 8 month winter). If you tend to drive your car in slow moving traffic a lot, that could be the cause (I think the word is that weather and dirt/rust can cause the surface of the disc to become uneven).
Take the beast out for a little while and drive balls to the wall - make sure to include lots of hard braking. If that doesnt fix it, it may be a resonance problem that is more annoying to get rid of. Ive seen people fix brake noise by changing to a different brand of brake pad and there might be some coatings available that might help. Id try some hard driving first and see if it works though, its cheaper and so much funner.
      11-27-2012, 10:30 PM   #11
richb811
richb811's Avatar
465
Drives: 2020 G20 330i M Sport
Bedding the brakes in properly and transferring the friction material to the rotors does help eliminate some of the squeak. Takes some time, some patience and a road where you won't get looked at like you are crazy man (if that bothers you)
Ceramics generally won't help the issue. Instead of a squeak you get a dull grinding noise.
m5post
