ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      06-11-2007, 01:39 PM   #1
alindsay
Drives: 2007 Z4 3.0si
HD antennae install
I recently purchased a Dice HD radio w/ipod integration. Does anyone have any hints or tips on how to remove the A pillar trim in order to run the HD antennae lead to the radio unit that will be located behind the glove box?
Thanks.
Alex H Lindsay
2007 Z4 3.0si
2001 K1200LT
Melbourne, FL
      06-11-2007, 04:47 PM   #2
TopDown
TopDown's Avatar
Drives: 2017 G30 540i M Sport
Thanks.
Yes (will post photos later).
1) Remove the two screws that hold the passenger side sun visor in place, then remove the sun visor.
2) Pull the A pillar trim to the right to separate it from the top windshield trim, and then pull it upwards - that's it. BTW, the tricky part will be getting the A pillar trim back in.
Also, you'll need to remove the passenger side air vent to continune running the antenna cable to the location behind the glove box.
Mine
G30 540i M Sport
Hers F36 440i Gran Coupe
      06-11-2007, 08:41 PM   #3
TopDown
TopDown's Avatar
DIY Photos - HD DICE Antenna Install
A pillar trim separates from windshield top frame trim. First remove two sun visor screws to remove sun visor, then pull A pillar trim to the right and then up.
Also need to remove passenger vent assembly by removing two screws. Lower screw accesible after deploying cup holder, upper screw accessible by removing decorative screw cover. Then just pull vent assembly out. (HD DICE antenna cable shown dangling).
Mine
G30 540i M Sport
      06-12-2007, 09:16 AM   #4
alindsay
Fantastic!!!
Thanks.
Alex H Lindsay
2007 Z4 3.0si
2001 K1200LT
Melbourne, FL
      06-12-2007, 09:30 AM   #5
takedown8
takedown8's Avatar
Drives: 2005 BMW Z4 3.0i
This should go in the DIY section, right intgr8r?
zpost
