06-17-2011, 01:05 AM | #1 |
Supreme Allied Commander
3857
Rep 54,416
Drives: F80 M3
New HPA E9x M3 Rear Ride Height Adjusters
A pair of adjustable height rear spring platforms, designed to work with 60mm inner diameter coilover rear springs mounted in the stock spring location at the rear of a BMW E8x (1 series) or E9x (3 and M series). These are high quality products made by HPA right here in the USA, with easy adjustments. The thread used is self locking once any load is applied.
The material for the rest of the assembly is made up of black and HPA blue anodized aircraft grade aluminum alloy. These can be adjusted from a minimum of 0.5" thick to a maximum of 2.75" thick. These can be adjusted independently of each other and is great for corner balancing of your BMW. This particular model has been optimized to run at the top of the spring on the back of a BMW E8x/E9x. The locating stub fits in the factory location and replaces the bulky factory locating stub/hat, which inhibits ride height adjustment with other similar rear ride height adjusters. Place your order here: http://www.hpashop.com/product.sc?pr...categoryId=218 $200 We are located in Santa Barbara, CA but we ship worldwide and have many satisfied customers around the globe. Please shoot us an email or give us a call and we are more than happy to help you. Last edited by HP Autosport; 09-12-2013 at 12:01 AM.. |
06-17-2011, 01:07 AM | #2 |
3857
Rep 54,416
Drives: F80 M3
Here is a couple of photos of our height adjuster with our quick change rear spring kit.
11-14-2011, 08:15 PM | #3 |
3857
Rep 54,416
Drives: F80 M3
These are perfect for those KW V or CS series owners looking for more ride height in the rear of their M3's.
02-15-2012, 11:55 PM | #4 |
3857
Rep 54,416
Drives: F80 M3
This is an easy way to get more ride height in the rear of your M3 for any coilover systems using 60mm springs.
If you have KW V3, CS or Competition and need more ride height, these will work with KW springs as well and has been very popular with the non-M 1 and 3-series guys with a faulty KW height adjuster design and/or too short of springs supplied, which allow insufficient rear ride height even fully extended. This height adjuster design also have added locator height for the installation of optional thrust bearings. |
09-27-2012, 01:05 AM | #5 |
3857
Rep 54,416
Drives: F80 M3
More ride height adjustment than the KW V and CS adjusters. Get these if you aren't able to get the rear of your M3 to the desired height.
12-05-2013, 11:57 AM | #8 |
3857
Rep 54,416
Drives: F80 M3
12-05-2013, 06:49 PM | #10 |
3857
Rep 54,416
Drives: F80 M3
