      06-02-2011, 09:20 PM   #1
Xaeryan
Xaeryan's Avatar
38
Drives: Sideways mostly
USB stopped working a few days ago
I've had the occasional issue where the USB drive/stick is no longer detected and you have to reseat it or cycle power to the radio, but recently I tried a different stick to mix things up. It didn't recognize it, so I put the original one back in. Well, needless to say that one doesn't work either now, and it's been a few days with no luck. I tried plugging the stick in directly (without a cable) and still nothing. The light on the stick comes on, but the USB option says Insert Drive each time I select it.
So is there any fuse or reset procedure that I might need to replace or do? Or is it time for a dealer visit?
      06-03-2011, 05:58 AM   #2
B50
Drives: 135i
2009 135i  [0.00]
I have the same problem, did you get it resolved
      06-03-2011, 11:16 AM   #3
Vorsprung_CJB
Vorsprung_CJB's Avatar
Drives: AW 135i
Did you try reformatting the USB stick with your PC? The file system can get corrupted depending when/how they are plugged in and out, especially into non-PC devices where you can't 'eject' them. I would wipe it and recopy your music and then try again.
      06-03-2011, 11:28 AM   #4
Xaeryan
Xaeryan's Avatar
38
I think that's a good idea and I'll give it a shot tonight and post results. Just strange that both sticks would have the same issue, although I guess stranger things have happened.
      06-03-2011, 11:38 PM   #5
Xaeryan
Xaeryan's Avatar
38
Formatted a few sticks and added music - no go. :-(
      06-04-2011, 05:03 PM   #6
Gray67
Noob to the Bimmers but loving the ride
Drives: 2009 128i Vert
wouldn't this be covered under warranty?
2009 128i Convertible, Jet Black, M-Sport, Active AutoWerke tune, LUX Angel Eyes
      06-04-2011, 05:38 PM   #7
Blader
Lotus Exige ClubRacer
Blader's Avatar
Australia
26
Drives: MY15 Lotus Exige CR
2010 E88 125i  [0.00]
Had mine replaced under warranty.
Lotus Exige CR …. Upgraded Stereo, Cruise Control, Rear Parking Sensors, Full carpet kit with sound insulation ..... its a daily driver
Charge Cooled TVS 1900, 3" bi-modal Exhaust, Moroso Sump, LSD, 60l Alloy Tank, Upgraded 2 Piece Rotors, 46mm Nitrons, Harness Bar and Forged Track Wheels with Yokohama AO50 R Specs for play time
      08-29-2011, 08:13 PM   #8
siegester
siegester's Avatar
345
Drives: '20 M340i
2020 BMW M340i  [0.00]
Ugh, mine did this today. It charges my phone still, but won't play music from my phone or any USB stick :-/
Does anyone know what the dealer replaced when they got theirs fixed, or if there is a fuse to check?
      12-20-2012, 10:58 AM   #9
2totalled2months
Drives: 2010 Toyota 4Runner 4x4
I had the same problem,,well still kinda do, I was using a PNY USB and it wouldn't detect, exchanged it for a scan disk USB, same content on it, now it sees it and plays just fine,,go figure, try swapping brands, maybe how they seat in the port.
      12-20-2012, 11:20 AM   #10
cdde323
some dude
Drives: 135i
USB ports/contacts surfaces have a certain amount of friction which will degrade the connection after so much of the ol' in, out... in, out. Power is going to be the last to degrade as it doesn't require a lot of integrity in the connection. New ports are about $50 and are relatively easy to swap.
/Craig
1addicts
