      06-19-2008, 07:04 AM   #1
BMWhokie
Drives: BMW 135i
Jack Points
Where is a good spot under the car to place some jack stands (front of car) after jacking the car up?
      07-20-2008, 11:13 AM   #2
emm3tt
Out Driving
emm3tt's Avatar
29
Drives:
I haven't yet seen a good thread showing how you can jack the car up, then place jackstands on each side (a la how one would perform an oil change). :iono:
I don't work underneath jacks supporting a car.
Emmett
01 E46 M3
      07-20-2008, 11:18 AM   #3
larryn
Drives: '97 332ti, '21 X5 45e, '16 GT4
Rhino Ramps FTW. I've yet to find a decent spot to put jackstands up front. I would not think of putting the thing up against the lower control arms, and there is little else that is uncovered.
      07-20-2008, 11:19 AM   #4
emm3tt
Out Driving
emm3tt's Avatar
29
Drives:
I have some rhino ramps that I quit using on my E36 because they wouldn't stop sliding from under the car when I was trying to drive up them.
Emmett
01 E46 M3
      07-20-2008, 11:21 AM   #5
larryn
Use carpet anti skid material on a freshly swept garage floor. Works great!
      07-20-2008, 05:12 PM   #6
AussieRacer
AussieRacer's Avatar
Australia
24
Drives: 2008 135i
If you have a jack that goes lower enough, beneath the engine is the front suspension sub-frame that has a jack point:
From there you can then place jack stands under the normal jack points.
Current: 135i Auto, Le Mans Blue - w/ Bridgestone RE-11 rears, GP Thunder 7500k angels, & "golf tee" mod plus a few M3 suspension bits and pieces...
      07-20-2008, 06:08 PM   #7
One&Only
Only 1 n Rome
One&Only's Avatar
Drives: '08 135i Coupe
Voila!!!!
Thanks for the simple solution....this will work fine using the same low profile floor jack I use on the MINI
Drives a Sawed-Off Shotgun
135i/SGM/Terra/Gray Poplar/Sport Pac/H&R Sport Springs & Sways/Heated Seats/Premium HI-FI/Sat
      07-20-2008, 07:43 PM   #8
emm3tt
Out Driving
emm3tt's Avatar
29
Drives:
AWESOME. Thank you. :headbang:
Emmett
01 E46 M3
      07-20-2008, 09:45 PM   #9
Lester
Drives:
Someone else suggested jacking up the rear until the front gets high enough to place a stand under it.
      07-20-2008, 11:20 PM   #10
emm3tt
Out Driving
emm3tt's Avatar
29
Drives:
My solution to that has always been driving my car up on blocks of wood sitting on the ground. This enables me to fit a jack under the car.
Emmett
01 E46 M3
      07-21-2008, 02:40 PM   #11
TitoSkulls
Drives: 135i
+1
That's what I've always done.
Sparkling Graphite - Savanna Beige - Grey Poplar - M Sport -Premium - HiFi
1addicts
