04-07-2024, 04:23 PM | #1 |
Rep 45
Heat Exchanger- CARB Number
Good Afternoon. I'm shopping for a heat exchanger. I noticed a performance model By Mishimoto has a CARB number. Is this important? Does California care about my new heat exchanger? Yesterday, I read that charge pipes can cause a visual inspection failure, really. Thanks
04-15-2024, 12:58 PM | #2 |
Rep 93
I would call and ask a few local smog shops. Not sure about heat exchangers specifically. If there is a CARB number, I assume it's not for no reason and one without a CARB *should* fail a visual inspection.
My Agency Power intake on my previous 340 *should have* failed visual inspections. 2 shops told me to put my original intake on if I wanted to pass. A 3rd smog shop passed me. |
essjon1152.00 |
04-17-2024, 06:40 PM | #3 |
Rep 3,730
What heat exchanger? Top mount or front mount?
Top mount will need a CARB EO. Mishimoto gives you a CARB sticker. The front mount is just a radiator and isn't subject to any emissions rule.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
04-18-2024, 12:18 PM | #4 |
Rep 45
Thanks, for the input. I went ahead and purchased a Mishimoto tmic for the sticker. I want to avoid the hassle of making the car smog legal every two years. I considered the Wagner but was told that there are fitment issues with my CS. I also considered EOS
04-22-2024, 05:11 PM | #5 |
Rep 961
There are no fitment issues with CS, I installed it myself with zero issues.
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | K&N | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf |
