07-25-2023, 02:51 PM | #1 |
Rep 299
Using wheel lug nuts (double nut method) to remove wheel studs
Apparently most/all local places don't carry m14x1.25 nuts. The largest size is m12. When I have to remove the wheel studs, can I use the double nut method using the wheel lug nuts or would doing that affect the lug nuts?
07-25-2023, 02:59 PM | #2 |
Rep 1,954
Drives: 2020 BMW M4 CS
There should be no issue using the wheel nuts. You should be using no where near the torque used to tighten the nuts on the wheel to get then to lock together. Only potential issue is if someone used red loctite when they installed the studs. This may then require heat to break the locite.
dawei21391.50 |
07-25-2023, 03:51 PM | #3 |
Rep 18,855
We always have 14x1.25 stud kits in stock, includes nuts (or available separately).
dawei21391.50 |
07-27-2023, 08:05 AM | #4 | |
Rep 299
Car-Addicted7215.00 |
08-02-2023, 02:47 PM | #5 |
Rep 1,318
For removal, do yourself a favor and just get one of these:
https://www.amazon.com/DEWILL-Broken...7Y1RG8C5&psc=1 |
dawei21391.50 |
08-19-2023, 11:48 AM | #7 |
Rep 502
Totally acceptable to use this method. I will add that it’s best to thread the nuts on so the outer faces of the nuts are touching each other. Leave the tapered faces opposite of each other to prevent damage to the seating surfaces if you plan to reuse the nuts.
dawei21391.50 |
