01-01-2023, 10:56 PM | #1 |
Rep 26
When auto start/stop is active does the ac blow warm
WHEN AUTO START/STOP IS ACTIVE AR A LIGHT WHEN THE ENGINE IS OFF - DOES THE AC BLOW WARM (warmer) OR IS THAT ELECTRICAL THROUGH THE 48 volt system????
Only cause we are down in Florida. |
01-02-2023, 02:13 PM | #2 |
Rep 1,597
Drives: '23 760ix; '23 X3; '23 MB wgn
I'd like to know this too, as I am headed to Fla in a couple of weeks. Putting the car in Sport mode seems not to defeat A/SS btw, at least for me it isn't.
BMWCCA
Current: 23 760ix (Carbon Black/Tartufo) (after first one totaled) '23 X3; '23 MB E Wagon Prior: BMWs (3,5,7 & 8 series (2x!)) X3, MB (C, E, and S), Alfa GTV, MGB, Audi (A4, A6), Saab, Volvo, Toyota, Lincoln, Chrysler, Oldsmobile, Chevy, Rambler. |
01-02-2023, 08:26 PM | #3 |
Rep 243
Sport does turn off ass
But it won’t if you adjust it so that the transmission is in comfort (I think it’s transmition, it is one of the engine setting within sport) |
01-09-2023, 01:51 PM | #4 |
Rep 1,597
Yup, I've got sport selected for steering and suspension but not transmission, and ASS does not turn off.
BMWCCA
01-09-2023, 03:07 PM | #5 |
Rep 7,488
Instead of using the SPORT driving experience mode switch...if you have a STEPTRONIC tranny...just pop the gear shift lever over into the M/S gate just prior to coming to a stop...and this will also put the tranny into sport mode and disable ASS.
In fact, if ASS shuts the car off & you'd prefer the engine to stay running or restart...just push the gear shift lever over to the M/S position...it will restart the engine and disable ASS. When you take off...just pop the gear shift lever back to the D position. You can do this without having to look down and select the different driving modes...your eyes can stay on the road without having to fumble around messing with that switch.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
01-10-2023, 09:57 PM | #6 |
Rep 26
02-07-2023, 09:43 PM | #7 | |
Rep 2
Don't think so...
In my '21 RX 450H, with the engine off, the hybrid battery runs the A/C for about 10 min and then the engine comes on for a few minutes charging the hybrid battery, and then goes off - the A/C is running cold the whole time. I believe the RX hybrid battery is bigger, so even with the Mercedes you'll be somewhat limited... Last edited by JoeMayo22; 02-07-2023 at 09:48 PM.. Reason: completed |
02-07-2023, 10:25 PM | #8 |
Rep 658
Drives: 2024 X5MC LCI, 2017 F86 X6M
It does. Not necessarily warm air but since the engine is off it just creates air circulation - not cooled air
2009 E71 X6 50i- Azurite Black - Sold
2014 F15 X5 50i - Sophisto Grey - Sold 2023 G70 740i - Oxide Grey - Sold 2017 F86 X6M - Donington Grey 2024 F95 X5M Comp LCI - Isle of Man Green |
02-08-2023, 05:57 PM | #9 |
Rep 2
It's cold air
So to complete my answer above, I tested this out today in my '22 M440ix which I believe has the same 48V hybrid system. I cranked the AC and stopped the car, Auto Start/Stop stops the engine. The air keeps blowing cold for about 15 seconds, then the fan dials itself down a notch, still blowing cold air, but at a lower rate. Engine still off. After about 30 seconds (give or take), the engine comes on and the fan turns itself back up with very cold air. So the bottom line is that you won't get hot in the car, with the engine stopped the AC works for a bit, at a lower rate, and when it feels it can't cool the air enough the engine kicks in to turn on the compressor, even though you're in the Auto Start/Stop mode.
02-08-2023, 06:02 PM | #10 | |
Rep 1,597
BMWCCA
02-16-2023, 06:30 AM | #11 |
Rep 26
In short, after holding the car for two months, the AC is not electric. And will blow warmer when engine is off - BIG SHAME - especially for us Floridians cause it is noticeable
GuynamedGuy22.00 |
