03-14-2021, 04:59 PM | #1 |
Rep 15
AUX Volume issue...
I'm currently installing an AVIN unit in my '13 E70 and am having an issue getting the AUX to work. It shows the level at zero and I'm unable to move it. Any ideas?
03-14-2021, 09:58 PM | #2 |
Rep 873
Do you have monitor connected to aux in? If so, when you unplug the aux, are you able to adjust the setting?
Oh, you should also check the following: HOME>Settings>Factory>Enter Pin>Vehicle: Aux Switching Mode: I have mine set to AUTOMATIC AUX Auto Switching: I have mine set to HARMAN (with a 13 E70, you likely also have the Harman/Becker CIC)
2013 X5M AW/Blk
Build Thread: https://www.xbimmers.com/forums/show....php?t=1499820 |
