ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Navigation, Audio, Bluetooth, Stereo, Electronics Talk
  TireRack
      08-04-2008, 11:31 PM   #1
tom_48
BMW Novice
tom_48's Avatar
Drives: M Coupe
2007 M Coupe'  [0.00]
Bluetooth problem
Does anyone has an idea why when I try to synchronise my phone through Bluetooth, it doesn't want to go past the "phonebook loading" part??? Most often it just disconnects my phone, and one time I was waited like 15 minutes for it to load but nothing happened.
I can dial number through the mic, but I want to be able to answer calls and stuff. Thanks guys
      04-08-2011, 10:24 PM   #2
Ksquared
Drives: 2007 Z4 3.0Si
I know this is a very old thread - but there were no responses and I'm having the exact same problem. My phone pairs and I can make hands-free calls; I can even use the voice control system. But my phonebook refuses to load and simply flashes "PHONEBOOK LOADING" without ever loading the phonebook. When I ask it to "read the phonebook" it responds that the phonebook is empty.
Does anyone have any ideas as to what the problem is? Am I doing something wrong? This is not covered in the telephone manual I received with my manual package.
I have a 2007 Z4 3.0Si. My phone is a Samsung Epic 4G Android and, as I said, it paired easily and works fine.
Thanks in advance for any assistance you can offer.
(BTW - at least you know I used the SEARCH function first - or I'd have never found this thread!)
Kerry
      04-08-2011, 11:13 PM   #3
fighting_fish
Drives: 2.5i Z4 2004
I paired up my phone and everything worked as expected out of the box. The only thing I did was make sure to update the Nav software to the last version (v32), before I did anything else.
Shamelessly copy pasted from Ron Stygar's post:
Part# 01 59 0 141 891, retail $8.90.
      04-08-2011, 11:49 PM   #4
Ksquared
I should have made it clear - I don't have the NAV system.
Kerry
      04-25-2011, 03:32 PM   #5
Ksquared
bump. Any help that anyone can suggest?
Kerry
      07-27-2011, 05:23 AM   #6
tikamak
Lebanon
58
Drives: 2006 Z4M Roadster TiAG/black
I have the same problem on samsung galaxy S GT9000.
The loading phonebook part is stuck at that.
      09-14-2011, 11:45 PM   #7
phil-simon
Drives: 2006 Z4 3.0si
Hi guys - since you paired your phone successfully, maybe you can help me: I purchased my 2006 Z4 3.0si Roadster from a used car dealer and it didn't come with a radio manual and I am having difficulties pairing the iphone 4. I am not even 100% sure the car has functioning blue tooth: The phone finds the car but when I punch in a pin-code that I believe I am supposed to come up with myself, it doesn't offer to punch it into the radio as well, it just doesn't accept the pin-code, period. I assume my car is equipped with bluetooth since I have the little mic for the hands-free caling on my steering column. Can you help?
Philipp
      09-15-2011, 11:22 AM   #8
ShakyDog
ShakyDog's Avatar
Drives: 2007 Z4 3.0i Alpine White/Red
Voice dialing does not use your phone book, it is seperate and you must set each voice user up with the commands. Kind-a sucks, but at the same time it needs to learn how you talk.
Steve
      09-15-2011, 11:25 AM   #9
gcochard
Drives: 2011.5 E90 M3
2011 BMW M3  [0.00]
Philipp
The bluetooth module should be in the trunk with a sticker that has the PIN on it.
      09-16-2011, 08:31 PM   #10
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
That's correct, only I have no use for bluetooth in my car since my exhaust
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm
Gone:z4m, boss 302, c6 z06, m6,z3m
zpost
