08-15-2018, 08:13 AM | #1 |
Rep 15
Is this knock ?
Hi Guys
Have a 2014 F10 M5 with 18000mls and it recently started making this sound. Sounds like a knocking sound or something being loose. Took it to the dealer and they say its normal. Sounds suspiciously like rod know to me ? The car is stock standard,still under motorplan and not tracked etc https://youtu.be/7_7YwyYcjF4 https://youtu.be/oT402WTOJHU |
08-15-2018, 07:43 PM | #4 |
Rep 1,124
I had similar noises, it turned out to be timing chain issue. It’s at a BMW dealership being fixed.
?When you have fast cars and bad luck, it's a lot easier to handle than having slow cars and bad luck.?
Kevin Harvick Last edited by WickedBMW; 08-16-2018 at 07:01 PM.. |
08-22-2018, 10:27 AM | #6 |
Rep 222
Timing chain issue. Where do you get that. I want know?
This is normal noice and it’s not engine. Transmission oil line and pump sometimes makes that noice. Don’t worry. 👍🏻 |
11-20-2018, 04:46 AM | #8 |
Rep 15
What can be done to remedy this? I understand that its nothing to worry about, but its hella irritating.
11-20-2018, 05:18 AM | #9 |
General
61736
Rep 19,945
I would suggest an engine oil flush, that's draining your old oil out and filling with special flushing oil and running at tick over ONLY,for 5 or so minutes then draining and refilling with 9.5 litres of Castrol 0-30 Edge together with the new o/filter(just what I use).
It should be fine but check the sealing security of your air filter enclosures and the air filters themselves if they're in good shape, the a/f enclosures are fiddly to screw back together and any unchecked gap could cause problems. Good luck. |
11-20-2018, 06:51 AM | #10 | |
Rep 15
11-20-2018, 12:21 PM | #11 |
General
61736
Rep 19,945
I heard it, video has gone now but if it is a pump pushing the ATF oil then there sure is a problem there with the racket it was making,it just wasn't right.Mine is silent as a lamb.
11-20-2018, 02:06 PM | #12 |
Rep 222
11-20-2018, 04:54 PM | #13 |
General
61736
Rep 19,945
11-21-2018, 05:02 AM | #16 |
Rep 1,107
Does the noise change from when the car is first started for the day to when the engines up to temp? It's tough with a video to get the sound across, if there was an issue it sounds valve train related.
'13 Black Sapphire Metallic - BPM Stage 1 Tune - RPI Exhaust - KW HAS Kit - 12mm spacers all around- Carbon Fiber front lip - High Kick Trunk Spoiler - Rear Roof Spoiler - IND Kidney and Fender Grills - 20% Tint all around 50% Front Windshield - PPF
11-21-2018, 05:09 AM | #17 |
Rep 15
No ,the sound stays there regardless of whether its cold or on operating temp. I must add that the noise is only audible when stationary. If the you let of the brake and let the vehicle just "creep" forward the noise goes away. The moment you depress the brake again and stand still you can hear it again.
11-21-2018, 05:45 AM | #19 |
Rep 15
At the moment its on 33k km (20,5k miles)
11-21-2018, 07:29 PM | #21 |
Rep 1,124
I was told by mechanic that specializes in M5s. Whatever dealership did it fixed that issue
Kevin Harvick |
