05-05-2018, 10:24 PM | #1 |
Rep 420
Done the ramair filter mod now have problems
Recently done the ramair intake mod which a lot of you guys have probably seen on the forum. The car was fine for a day or 2 untill I recently went out tonight for some harder driving..
Car was low on fuel and just as I was about to get to the fuel station I had restricted power flash up with drivetrain malfunction and misfires.. I turned the car off, fueled up and everything seemed fine.. so I done a few pulls and the cel flashed up and has stayed on for a few hours, car has full power and no drivetrain fault just a cel on I'm guessing the intakes are causing this? I've recently done an exhaust mod which I opened up the rear muffler flaps and tied them open, I left all vac lines plugged in? Thankyou |
05-06-2018, 06:34 AM | #4 |
Rep 1,123
05-06-2018, 02:00 PM | #9 |
Rep 385
You can pull the codes with any OBDII reader and see what it is. No need to be in the dark. Lots of chain auto parts stores will let you use one for a few minutes if you don’t have your own.
05-07-2018, 01:20 AM | #11 |
Rep 673
I did charcoal delete and K&N drop in after a few months had the same code, Bank 1 lean. After research of this issue I did the recommended cleaning of the MAF with MAF cleaner. Reinstalled and no CEL since!
05-07-2018, 09:04 AM | #12 | |
Rep 294
2019 F90 M5 Competition - Marina bay Blue Pearl - Executive and Bowers & Wilkins package
Gone:2013 F10 M5-DCT-Montecarlo Pearl Blue-BBMR 800 Stage 1 system 700whp+(93oct) 2004 Lamborghini Gallardo-Manual-Giallo Midas Pearl Yellow-Modified 2018 Range Rover Velar S-White |
05-10-2018, 04:36 PM | #15 |
Rep 294
I recommend you switch to the BMS intake or K&N cone filters it has better filtering....you dont want small dirt particles entering your engine
