M5POST
      02-06-2018, 08:07 AM   #1
Fast400
Fast400's Avatar
Germany
683
Drives: iX M60
2014 BMW  [0.00]
DCT Oil Change coming
Will be putting a DCT oil change video out real soon....here's a preview
///3dkn1488.50
cali_m527.00
M5Rick60060.50
94jedi830.00
      02-14-2018, 01:28 PM   #2
Fast400
Fast400's Avatar
Germany
683
Drives: iX M60
2014 BMW  [0.00]
The promised video to DIY DCT fluid change. EDIT!!! Make sure to use ISTA+ and use the "Service Function". A German Forum member said it would make a difference...I didn't believe it. I re-checked my fluid level again using ISTA+, and there actually was a 400ml difference. I know that's not much, but still better to be safe.
I've added the ISTA+ bit into the video...it's just an overview of using the program when performing the fluid fill.
123Britt289.00
Mcc420475.00
      02-14-2018, 03:22 PM   #3
SapphireM5
SapphireM5's Avatar
711
Drives: 2013 M5 Sapphire Black
Great video as usual! Thanks again for making these videos and sharing!!
'13 Black Sapphire Metallic - BPM Stage 1 Tune - RPI Exhaust - KW HAS Kit - 12mm spacers all around- Carbon Fiber front lip - High Kick Trunk Spoiler - Rear Roof Spoiler - IND Kidney and Fender Grills - 20% Tint all around 50% Front Windshield - PPF
      02-14-2018, 10:42 PM   #4
Guy M5
Scotland
17
Drives: M5 F10 2014 MCB
Excellent, thank you!
      02-15-2018, 03:51 AM   #5
Craze
Drives: M5 E60, M5 F10, X5 50i
Isnt factory fill much more? Should it be done twice??
      02-15-2018, 04:25 AM   #6
Fast400
Fast400's Avatar
Germany
683
Drives: iX M60
2014 BMW  [0.00]
If the transmission is a new exchange, then yes. If you are simply draining, filling, and changing filters, you'll get approximately 6.5 Liters out.
I think doing it twice would be a waste of money, for normally used M5
      02-17-2018, 10:42 PM   #7
alienstudio
alienstudio's Avatar
30
Drives: F10 M5 CP | G05 X5 40i
You are the man!!
2014 F10 M5 CP | Black Sapphire Metallic | Sakhire Orange Interior | 343M Wheels | Afe CF Air Scoop | Charcoal Filter Delete | AutoTecknic CF Steering Wheel Trim
      02-19-2018, 05:24 AM   #8
Fast400
Fast400's Avatar
Germany
683
Drives: iX M60
2014 BMW  [0.00]
Folks! I just learned a bit extra.
A German M Forum member said I should have used ISTA+ to measure temperature and perform the "Service Function". He said it may make a fluid level difference.
So I figured what the heck, I'll re-check using ISTA+. I expected no change in fluid level. I wound up adding about 400mL on top of the 6.5L I added previously.
I couldn't believe it! I don't think it would be super detremental, but if we're going to do it, we want to do it right....so I'm going to edit the video to show the ISTA+ portion too.
      02-19-2018, 06:25 AM   #9
Guy M5
Scotland
17
Hmm, thanks for adding that, it looks like I'm going to have to factor in purchasing ISTA+ now, this is not going to be cheap but still cheaper than the dealers and ISTA+ can be used for other things I suppose.
So 7 litres of oil now.
      02-19-2018, 06:39 AM   #10
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
Very helpful; thanks!
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      02-20-2018, 10:48 AM   #11
Blaxwil
Blaxwil's Avatar
627
Drives: 2015 M5
Ive seen a few different oil change interval schedules. What is recommended for a non CP 2014 M5?
      02-20-2018, 12:49 PM   #12
Fast400
Fast400's Avatar
Germany
683
Drives: iX M60
2014 BMW  [0.00]
According to BMW...never
According to Getrag every 80k km (50k mls)
I did it way early at 50k km's...just to make the video for folks.
      03-05-2018, 03:24 PM   #13
rsuhandy
rsuhandy's Avatar
Drives: F06 M6;E92 M3;E85 Z4M; 958 SEH
Thank you for the video!
How much was the mojo power pan?
I can't seem to find where to purchase it online.
Did you go through HTD performance?
      03-06-2018, 09:30 AM   #14
Fast400
Fast400's Avatar
Germany
683
Drives: iX M60
2014 BMW  [0.00]
I bought it here: http://htd-performance.com/en/744/
Around $1000
      03-06-2018, 11:08 PM   #15
rsuhandy
rsuhandy's Avatar
Around $1000
Thanks!
Did you end up using the filters that come with the mojopower kit?
Or did you go OEM?
      03-14-2018, 09:16 AM   #16
Fast400
Fast400's Avatar
Germany
683
Drives: iX M60
2014 BMW  [0.00]
Thanks!
Or did you go OEM?
The side filter was oem 'Getrag'. I felt comfortable using the bottom filter. Looked OEM too.
      03-23-2018, 11:10 AM   #17
finlandm5f10
Drives: BMW M5 F10&Audi RS6 C7 2016
Hi. Did you use in first time measuring the oil temperature bimmerlink app? And German language some getribetemperature?? Have test to drive and look this temperature??? Never goes over 55-57 celsius. This is not show transmission oiltemperature. It shows one sensor which is top the transmission.
      04-01-2018, 08:02 AM   #18
malcoll
Drives: 2014 M6GC BSM/SO
Around $1000
So how the heck do you actually purchase their products? I've been searching their "website" and have yet to find a way to order the pan? How did you complete your order?
Thanks,
Lance
      04-23-2018, 01:23 PM   #19
finlandm5f10
Up up??
      05-04-2018, 02:22 AM   #20
Fast400
Fast400's Avatar
Germany
683
Drives: iX M60
2014 BMW  [0.00]
Up up??
Hi, I used ISTA for the fill temperature. When driving I used the Bimmerlink...it was much easier. Getriebetemperatur does show the Transmission temp.
      05-10-2018, 01:40 PM   #21
finlandm5f10
Not. This is not show TRANSMISSIONOIL temperature!!!! (bimmmerlink)
How much this bimmerlink show when you are driven maybe 30-45min city driveing or highway?
      05-30-2018, 12:51 PM   #22
Fast400
Fast400's Avatar
Germany
683
Drives: iX M60
2014 BMW  [0.00]
Sorry for the late reply. With Bimmerlink temp is 54 C after 20 minutes of autobahn then stop n go for 10 minutes.
m5post
