M5POST
      01-31-2018, 04:22 PM   #1
V8munro
V8munro's Avatar
United Kingdom
49
Drives: F10 M5 Sakhir Orange
intermittent timing issue (crank or cam sensor?)
car was misfiring today, as got warmer it gradually managed to hold idle and then after a while wouldnt cut out under revs, looked logs and car was idling and on partial throttle at 25degrees of timing then cutting to 0 on misfires. from my basic knowledge ive taken this as likely to be the crank or cam sensor playing up, even more annoying the car is now running fine and returned back to normal with car running fine. do these cars have any common issues with cam or crank sensor and where is the crank sensor located?
F10 M5 2013 Sakhir
Eventuri Intakes, Supersprint backboxes, catless downpipes, ssp spec r, ECU flash, JB4 BCM and BMS dual CM10 meth
Insta: Tommy_turb0
      01-31-2018, 05:06 PM   #2
V8munro
V8munro's Avatar
United Kingdom
49
FYI: Crank position sensor goes into the side of the bellhousing
F10 M5 2013 Sakhir
Insta: Tommy_turb0
      02-01-2018, 03:01 AM   #3
Fast400
Fast400's Avatar
Germany
683
Drives: iX M60
2014 BMW  [0.00]
What you described is a bit vague. If you can perform a read from your OBD II, you can maybe see what codes your getting. The misfire could be coilpack, sparkplug, fuel pump, pressure regulator, bad fuel.....or intermittent cam/crank sensor. Kind of in that order more or less. There's even more things that can cause a misfire, but those are the most common.
      02-01-2018, 05:04 PM   #4
V8munro
V8munro's Avatar
United Kingdom
49
Fast i changed the crank sensor today and problem remained but car started driving better longer it was running. I was making alot of boost on meth and jb4 so i left meth on and turned extra boost additive off. With the big cm10 nozzles i think i may of thrown my adaptions out the window as afr, timing and fuel trims were all over the place. After putting 50miles on the car its now driving as should as afr, timing and fuel trims and back where they usually are. Not sure what happened but me messing it up is a high possibility with cm10 nozzles to keep afr in range at lower boost fuel is probably reduced alot. All new to me but its all back to normal.
F10 M5 2013 Sakhir
Insta: Tommy_turb0
      02-02-2018, 01:53 AM   #5
Fast400
Fast400's Avatar
Germany
683
Drives: iX M60
2014 BMW  [0.00]
Glad you got it worked out!
m5post
