01-16-2018, 09:41 AM | #1 |
Rep 1,632
New to wheel fitment on the F80 need help
Hi guys,
Im wondering who's running on 19x10 fronts and 19x12 rears? Im coming from the e9x so im not sure if the F80 can take that much width in the rears? If yes what offset i should get? Im planning on running coilovers and i want a flush fitment Thanks Mike |
01-16-2018, 10:40 AM | #2 |
Enthuisiast
93
Rep 423
Can you run those sizes...? Probably...
It depends on your desired offset and tire size. If you want something that is stanced out and performance/alignment don't matter then yes... you could probably run those wheel sizes with a stretched tire and some negative camber. If you want something that is going to perform better than stock and want to upgrade the tire contact patch, you'll probably want to stick to an 11 inch wide in the rear. The E9X cars can run much more aggressive fitments in the rear compared to the F8X. Fronts are about the same. So, what are you planning to do with the car? That will really determine what wheel/tire/offset is right for you.
AW F80 M3 / RAYS / TOYO TIRES / BMS
IG: @hybrid_david |
01-16-2018, 01:38 PM | #3 |
Rep 1,507
Drives: '12 Nardo E92 '15 Fashion F80
Yes, those sizes can be done. I personally know people who have custom built those sizes. I personally have 20x10 and 20x12 built wheels on my F80. Its doubtful you will find those sizes off the rack though.
01-17-2018, 09:48 AM | #4 |
Rep 1,632
I dont want to camber/stretch i want a flush fitment lowered on coilovers !!
Forgestar now offers the F14 wheels in super deep concave 19x12 for the rears |
01-18-2018, 08:14 PM | #5 |
#dubspec
6344
Rep 5,201
what is the reason for such wide wheels? what tire size do you plan on using?
for reference, im running 9.5/11.5 sizes. only reason i went with 11.5 is to seat the 305 rear tire better. an 11" rear will mount a 305 no issues as well since i have used that sizing in the past. ps: im in Ottawa as well if you need help with fitment
LCI ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow instagram: @ dubsesd Last edited by dubsesd; 01-18-2018 at 08:29 PM.. |
Signature Wheel BMW1112.00 |
01-18-2018, 09:03 PM | #6 | |
Rep 1,085
With that in mind, let's start with what suspension are you running? Photos of your car's current ride height? What tire brand and size do you plan to run? Once I have those info, I'll give you a very specific fitment that's proven not to rub and will be tastefully flushed.
Jimmy | BMW Addict | Signature Performance Wheels | OBSESSED WITH PERFECTION | IG: Signature_BMW | Email: jimmy@signaturewheel.com
01-18-2018, 09:55 PM | #7 |
Rep 145
Another wheel noob question. I'm thinking about picking up a set of signature wheels, but I'm wondering how resell-able they are. Would I only be able to resell to another BMW or /m specific owner should I sell the car down the road, or it is a rather common fitment that would work on other makes/models?
I want wheels, but I may sell the car when the mid engine corvette comes out, depending on price and performance. I'm definitely intrigued. |
01-19-2018, 12:58 AM | #8 | |
Rep 6,659
01-19-2018, 08:42 AM | #10 |
Rep 1,085
Bolt pattern of the M3/4 is 5x120. Feel free to message directly so you're not thread jacking (a sin on the forum).
There's more to custom made wheels than bolt patterns. They're truly hub centric (72.6mm) and OEM lugs seat angle compatible. So the M3/4 wheels can fit on an E9x M3 for example, with some spacers in the rear or it can be fitted on an M2 with suspension/camber. With thousands of M3/4 floating around, you won't get too much trouble reselling the wheels especially between March and September.
01-19-2018, 10:57 AM | #11 | |
Rep 1,632
I think i will go 9.5" & 11" after reading more on fitment |
01-20-2018, 02:22 PM | #12 |
Rep 1,009
Can you explain what this means? In this pic it looks like even with 305 tires there’s a tad bit stretch on 11.5” wheels. Not much. It’s similar to how OEM 285/30/20 MPSS looks a tad bit stretch on the CP. Is this done on your car since you want to maximize your drop (minimize you wheel gap with a slight tuck of the tires)? Are your fenders rolled?
01-21-2018, 04:38 PM | #13 | |
#dubspec
6344
Rep 5,201
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow instagram: @ dubsesd |
