07-12-2017, 03:07 AM | #1 |
Lost Motorcyclist
167
Rep 379
20×9.5 ET17 front wheels?
Hi guys,
With all the talk about the KW spring fouling issues etc.... My question is with the above spec front rim and 265 tyres fitted do we have any outside clearance issues? Does this setup require extra camber etc? I drive this car every day in some bumpy roads and don't want any rubbing issues. Cheers, |
07-13-2017, 01:47 PM | #4 |
6585
Rep 5,305
It'll look a bit aggressive without some negative camber, but it should work without any issues. Keep in mind that some tires run wider than others even when listed as the same size.
Also, the new version of the KW HAS has solved the over sized spring perch issue. |
07-13-2017, 01:49 PM | #5 |
3138
Rep 2,953
Depending on how low you are, you might rub with the 265. I ran the same on my LM-R.
The 265 will rub on the perch if you have the old AN part number. the 255/30/20 is a better option that should not rub |
07-13-2017, 02:11 PM | #6 | |
6585
Rep 5,305
To OP. I didn't see the 20" part and I was going by 19" wheels. Do as Justin says; he knows something. |
07-13-2017, 05:56 PM | #7 |
Lost Motorcyclist
167
Rep 379
Thanks for the reply all,
I should add my current front wheels have an ET22 in 20x9.5. With a 255/35 ive got 6mm clearance with how low my car currently is. So I'm looking at replacing the with et17 due the the kw clearance issue. I'm not wanting to run the car super low. Unfortunately tyre choice here is limited due to what gets imported, not much option in the 255/30 space and I hate the stretched look! I have a 255/35 on now but the rolling diameter (being 1" too tall) is messing with the traction control I think. Regards the new KW setup, it appears that it's a US thing, I spoke to the Australian importers and they cannot see a listing for it, only list the old P/N....if I could just buy the fronts as opposed to a whole new kit for a reasonable price I would probably do that from.... well Auto Talent, or another fine US seller. If I can source the parts cheap enough, I'm considering going back to stock springs! I should add, looking at V105 yokohama's in the 265... specs on them don't seem too wide... Cheers, Last edited by ruley74; 07-13-2017 at 07:30 PM.. |
07-13-2017, 10:26 PM | #8 | |
Rep 1,085
Below is 20x9.5 ET17 front with MP4S 265/30/20.
Jimmy | BMW Addict | Signature Performance Wheels | OBSESSED WITH PERFECTION | IG: Signature_BMW | Email: jimmy@signaturewheel.com
07-14-2017, 01:54 AM | #9 | |
Lost Motorcyclist
167
Rep 379
KW importer here in Oz is talking to KW in the US about sourcing the parts I need to swap the front out. Cheers, |
07-14-2017, 06:07 PM | #10 |
3138
Rep 2,953
07-19-2017, 09:10 PM | #11 |
Lost Motorcyclist
167
Rep 379
Just for close out, I fitted the 265 Yokohama V105 to the front of my car with ET22 9.5 inch rims and the KW HAS kit without issue, they definitely run on the narrow side of 265.
07-19-2017, 09:58 PM | #12 |
Rep 4,114
So does the new perch fit the old HAS?
http://f80.bimmerpost.com/forums/sho...1393146&page=2 Can someone confirm please? |
07-24-2017, 07:22 PM | #13 | |
Rep 12,654
07-25-2017, 02:22 AM | #14 | |||
3138
Rep 2,953
The perch and front spring have both been redesigned |
07-26-2017, 12:37 PM | #16 |
Rep 4,114
You can purchase the complete new kit
#253200ANU We are unable to sell just front You will need wheel spacers even if you got new kit. I would do some measurements and I included a link to help you out. http://www.st-suspensions.net/wheelspacerfinder Please call us to verify part numbers and it is offered in North America, The link is to our international site. Wow.... what a great service!
07-26-2017, 12:43 PM | #18 | |
Rep 4,114
Sound pretty good! But after the email I got I prefer to put the KW kit in the trash and go with a other company They can't sell front only...lol... what they doing in a waranty case?
07-26-2017, 12:44 PM | #19 |
Rep 12,654
PM me what you are looking for exactly and I will get it for you. Easier to go through a distributor
07-26-2017, 12:49 PM | #20 | |
Rep 4,114
Edit: fixed
07-29-2017, 01:16 PM | #21 |
Rep 4,114
