M5POST
      04-20-2016, 10:24 AM   #1
Sabs1815
Drives: 2013 F10 M5
Low Coolant Warning
Hello All,
Had a weird experience this morning with the M. I got in my car this morning and started it cold. After a few minutes of idling I got an error stating that I was low on coolant. The car has 39,000 miles on it and isn't due for service until June. I was able to get it on a lift to see if there were any leaks.Thankfully I couldn't find any! I refilled my reservoir and my error light went away seems like all is okay now.
I'm just curious if it makes any sense that the car would be burning coolant or if there is any logical reason why I would lose coolant if there is no leak.
      04-20-2016, 10:37 AM   #2
bobblehead
bobblehead's Avatar
Drives: warp speed
http://f10.m5post.com/forums/showthread.php?t=1052661
I see you have a 2013, has yours coolant tubings been retrofitted ?
      04-20-2016, 10:42 AM   #3
Sabs1815
Drives: 2013 F10 M5
I honestly wouldn't know. I picked up the car a month ago from Park Ave Group. I guess I will have to take it to the dealer to find out.
      04-20-2016, 11:05 AM   #4
bobblehead
bobblehead's Avatar
Drives: warp speed
You better find out real soon.
      04-20-2016, 11:23 AM   #5
jahdish
Insta pjahdish
Drives: 18 BMW M5/BMW X6/Ferrari 458
I have a '13 w 37k on the clock. Two weeks ago same warning. Topped off myself and warning went away. I had a service the next week and shared with my dealer. They did a pressure test and everything is good
      04-20-2016, 11:34 AM   #6
Sabs1815
Drives: 2013 F10 M5
Just called the dealership they have record of it being done last May. I'm due for service in two weeks anyway so they're going to check it out.
      04-20-2016, 11:35 AM   #7
Sabs1815
Drives: 2013 F10 M5
Hopefully it'll be the same for me. Getting it checked out when it goes in for service.
      04-20-2016, 12:21 PM   #8
bobblehead
bobblehead's Avatar
Drives: warp speed
that's good to hear. Hope the dealer will find out the issue (fault) for you.
      04-20-2016, 07:43 PM   #9
allmotor_2000
F10 1/4 WR: 9.9s / 142.5mph 1/2 WR: 175.5mph
1087
Drives: 2018 RS3, 991 Turbo
If you pop the plastic cover over the turbos and see heat-shielding on the turbo coolant pipes, it has had the update.
BTW, to confirm... which coolant - IC or Radiator? Which one did you fill up... one on the driver-side or passenger-side?
      04-20-2016, 07:45 PM   #10
Sabs1815
Drives: 2013 F10 M5
The car didn't state low ic coolant it was complaining about engine coolant. I refilled in the reservoir on the drivers side and the error went away.
2006 E46 M3 Vert-Sold
2013 F10 M5- Sold
2013 E70 X5M-Sold
2013 F10 M5- Rest in peace
2015 F15 X5 50I
      04-20-2016, 09:13 PM   #11
bigtex
Drives: 2013 BMW M5 - sold
Usually but not always, if the coolant is low, the system has a leak. I would bring it in to have it checked especially if your warranty is expiring soon. Do you smell burnt coolant after a spirited run?
2013 M5 - sold
2011 E90 M3 - Sold
      04-25-2016, 10:32 AM   #12
Sabs1815
Drives: 2013 F10 M5
Nope haven't smelled any coolant...... Im away traveling this week so I haven't really been with the car to see if anything would have changed since i refilled it.
      05-02-2016, 05:47 AM   #13
ur20v
Drives: F10 M5
silver heat sheild sleaves mean they may have just checked the lines and fitted the sleaves, if they still leak new turbo lines are required.
Mine has the heat sheild sleaves AND leaks from the small flexi lines in them so goes in this Wednesday to have new lines fitted.
See attached SIB
      05-02-2016, 03:50 PM   #14
Sabs1815
Drives: 2013 F10 M5
Scheduled my service its going in tomorrow. They're going to check everything out.
      05-03-2016, 05:46 PM   #15
Sabs1815
Drives: 2013 F10 M5
So i just got word back from Life Quality BMW. It's leaking coolant from the Turbo Lines . Looks like the start of a long week!
The best part is they don't have a loaner to give me so I'll be stuck driving the wife's Beetle
      05-04-2016, 08:46 PM   #16
bigtex
When the dealer replaced mine I got it back the next day. You should get it back quick. Make sure they replace the lines going to both turbos as if the lines going to one turbo needs to be replaced it is likely the other set will soon fail too. It will save you another trip to the dealer.
2013 M5 - sold
2011 E90 M3 - Sold
      06-02-2016, 06:09 AM   #17
ur20v
Drives: F10 M5
Its a couple of hours to replace the lines, it may be they needed to order the parts.
      08-27-2016, 07:10 PM   #18
daddymalu
Drives: M5
My car has 18k miles and had to top of drivers side reservoir... Hopefully that will last till the next service in 3000 miles...
      09-13-2016, 01:26 PM   #19
Rosspbig
Drives: 2013 M5
When you guys are topping off the coolant, are you just pouring 100% coolant in, or are you premixing it 50/50 with water?
m5post
