XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 DIY (Do-It-Yourself) Discussions
Register FAQ Calendar Today's Posts
      08-17-2015, 06:04 PM   #1
tuanvo1982
Australia
Drives: BMW X1 xdrive20d 2010
DIY - X1 Phone cradle removal needs help
Hi there,
I try to disassemble the armrest in order to remove phone cradle. However, my X1 x20d 2010 does look the same as any instruction on this forum. Anyone knows how to de-attach the cradle please help me.
- I could remove the back of armrest as you see in the photo
- Remove the top one as well but the armrest and the cradle seem to be a whole unit. I try to put a pin which connect them together from left to right and right to left but does not work at all.
Thanks
      08-17-2015, 06:36 PM   #2
improvius
Drives: 2015 X1 X28i
I never really looked at these adapters before, but HOLY CRAP are they crazy expensive. Upwards of $200 for a glorified usb cable? Are you kidding me?
Sorry I don't have anything helpful. Worst case, you can always take a Dremel to it. Good luck!
      08-17-2015, 06:51 PM   #3
tuanvo1982
Australia
Anyways Cheers mate, the worst case I will chop/break it off simply and de-attach the cable.
      08-17-2015, 08:20 PM   #4
PrematureApex
Drives: N55 X1, N54 135, s54 m3
Hit the pin harder. Seriously...iirc it eventually popped out.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      08-17-2015, 08:41 PM   #5
tuanvo1982
Australia
Which direction should I hit ? right to left or left to right? Did you try that?
      08-18-2015, 12:28 PM   #6
PrematureApex
I pushed from the right side to the left. Had to give it a bit of elbow grease to get going, but after that, it was easy.
      08-18-2015, 07:38 PM   #7
tuanvo1982
Australia
Thanks mate, I give that a go tonight.
      08-21-2015, 07:44 AM   #8
quiksilverdad
Drives: x1
http://www.bimmerfest.com/forums/sho...=735489&page=2
Originally Posted by Hen49
How safely remove phone cradle.
1. Move forward front seats to max. Easy 10min job. I use 2 flathead screwdriver mid & small.
2. Start right bottom of back panel center console (with cigarette lighter).
3. Release snap clips (vertical grove) there are 3 clips on both side.
4. Slide forward the center armrest.
5. Pull back panel center console upward.
6. From right side push axle-pin.
7. From left side pull pin like 4 inch don't remove it.
8. Open cubby and remove phone cradle.
9. Reverse process.
Done.
One more cover hole inside cubby use thin cardboard or plastic + super glue.
Maybe some made few pics and better description how remove back panel of center console.
It took me over an hour, but mainly because I struggled on disconnecting the wires. Removing the back cover was no problem using a flat screwdriver to start the process. I used a nail set and a mallet hammer to start pushing the axle pin toward the drivers seat.
Removing the blue/pink cable was no problem since the release lever was fairly obvious. Removing the pink/black cable was difficult until I found that I had to remove the pink cover in the photo below. I pried it out with a flat screwdriver. The release is under this cover.
      08-22-2015, 07:04 AM   #9
tuanvo1982
Australia
9. Reverse process.
Done.
Thank you. Actually I have read that many time but the article does not seem to work for me. I will try to push the pin tomorrow Sunday
      08-22-2015, 12:09 PM   #10
Alanintx
ATAP
Alanintx's Avatar
Drives: 2017 Midnight Blue 430xi GC
Look closely at the pin. One side of the pin has grooves in it, similar to the hinge pins on the doors.
The grooves are what lock it in place. It needs to be whacked out, pushed from the opposite side which is tapered.
BTW, I did it the wrong way and it still worked, just a bit harder.
      08-22-2015, 07:00 PM   #11
tuanvo1982
Australia
I have done it. Now I have more space. Just did it from right to left. I got rid of stupid cradle
      08-22-2015, 07:13 PM   #12
tuanvo1982
Australia
This is the picture after I have completed
      08-14-2020, 11:05 AM   #13
4ndres
4ndres's Avatar
Drives: BMX X1 xDrive35i
It's been a long time since this thread was active, but I thought I'd add that there is a cap you can put in the hole that is there after removing the phone cradle if you want a more finished look.
PN: 51-16-2-991-863
Dres
      08-24-2020, 12:04 PM   #14
Sulphurman
Sulphurman's Avatar
20
Drives: BMW X1 E84 1.8d Xdrive
https://www.youtube.com/watch?v=66oowXEGqGk
      12-13-2020, 09:28 PM   #15
Bali
E46 Fanatic
Bali's Avatar
Drives: E46 E84 F15
Thanks, that oart number is correct.
PN: 51-16-2-991-863
I ordered that part and it fit the hole perfectly on my 2013 X1 sDrive28i. Thanks for posting the part number!
xbimmers
