06-11-2015, 02:32 PM | #1 |
Rep 255
passenger side mirror drop in reverse
so the passenger side mirror drops down each time I go in reverse. which is fine. and I know if I put the button in the car to the right it won't dip at all when reversing. my question is how do I change the amount it drops down? is it possible to change how much it drops? it drops down quite a bit farther than I'd like it to.
2015 M4 Sakhir Orange, Executive Package, Adaptive M, 19" Wheels, Black Merino Leather
06-11-2015, 02:45 PM | #2 |
Rep 324
Thats a first, I have yet to hear someone complain about this. I wonder if its in any way connected with how you have your mirrors adjusted? Like does it dip down a specific distance (from where you had it saved as your preference) or just goes all the way down anyway?
06-11-2015, 02:49 PM | #4 |
Rep 255
it drops down to the curb and road and I can't see anything actually behind me in that mirror. I'd like to have it dip down just a little so I can see the curb better but not so much that I can't see anything behind me. it dips really far down.... I have to adjust my head height in order to even use it at all. I usually just leave it off cuz it's kinda useless as is right now. but it's a cool feature I'd love to use if I could set the amount it dips.
06-11-2015, 02:50 PM | #5 | |
Rep 255
06-11-2015, 02:52 PM | #6 |
Rep 684
Drives: 2023 G80x M3C
You are only supposed to see your expensive wheel and how close it is to the curb with that dip. Who cares about the person behind you are about to hit?
2023 G80x M3C | 2018 X5M [Current]
21 G80 M3C | 19 AUDI RS5 | 15 F06 M6 GC | 18 AMG C63S Coupe | 15 F82 M4 | 14 M235i | 08 E92 328xi | 95 E36 328i *R.I.P* [Previous] |
Kilabyte3948.00 |
06-11-2015, 02:52 PM | #7 | |
Rep 816
If it's going down too far it probably means your mirror isn't set up properly from the start. To see behind you use the backup camera.
06-11-2015, 02:53 PM | #8 | |
Rep 255
06-11-2015, 02:55 PM | #9 | ||
Rep 255
06-11-2015, 02:57 PM | #10 | |
Rep 255
06-11-2015, 03:40 PM | #11 | |
390
Rep 859
Drives: 2017 Alfa Giulia Quadrifoglio
06-11-2015, 06:50 PM | #12 |
Rep 191
Put the car in reverse, switch your mirror adjustment to the passenger side, the mirror will return to the normal position.
Now adjust the mirror to where you'd like it to be when reversing. Switch the adjustment to the drivers side, your passenger mirror should be where you left it. Disengage reverse, passenger mirror should return to normal driving position. The passenger mirror will now move to the position you set whenever reverse is selected. |
06-11-2015, 07:09 PM | #13 | |
Rep 255
06-11-2015, 09:42 PM | #14 | |
Rep 255
06-12-2015, 08:46 AM | #16 | |
Rep 255
06-15-2015, 11:17 PM | #17 |
Rep 255
just wanted to let you guys know I did get this sorted out with coding it. works perfectly now!
06-18-2015, 09:03 AM | #18 |
Christmas Poo
1070
Rep 1,196
I couldn't get mine adjusted on my own adequately - was pointed too high when driving and still too low in reverse (didn't have backup camera). So I coded it not to drop as much:
FEM_BODY - ASP_BORDSTEINAUTOMATIK_DELTA Coded to Werte = 22 (default was 3B or 59 points) In the meantime I've also added the Bimmertech backup camera retrofit and it works great. |
audioMeth222.00 |
09-23-2015, 02:10 AM | #19 | |
Rep 58
ASP_BORDSTEINAUTOMATIK_DELTA What I see is this: FEM_BODY - 3110 ASP_BORDSTEINAUTOMATIK aktiv werte=01 So I'm not sure how to set this. |
09-24-2015, 07:11 PM | #21 |
Christmas Poo
1070
Rep 1,196
Interesting. The setting is in my FEM_BODY...but I have the older software version on my car as well so perhaps they changed the setting? :
Did you go back to the top of the list of codes when you searched? Maybe you missed it...otherwise not sure I can help. Maybe just search for delta?
09-25-2015, 11:27 AM | #22 |
Rep 58
Yep, I did all that and searched everywhere within the FEM_BODY module and couldn't find ASP_BORDSTEINAUTOMATIK_DELTA. I checked my I-step of my car and it is F020-15-07-504. I also noticed that the target I-step (the one i picked when I initially connect my laptop to my car) is F020-15-07-506. Not sure if that would affect things. I'm at a loss now, shawnsheridan would you have any insights on this?
