M5POST
      12-30-2014, 02:28 PM   #1
JR429
Drives: W212, GTR, 997 TT; F10 M5
Excessive oil consumption?
Anyone else experiencing excessive oil consumption? I dropped in 2 quarts for 3000 miles (total 4400 miles on car). There's a few threads about it here but has anyone had any solution from the dealer?
I refuse to accept 1 quart per 1000 miles is "normal" operation (as told to me by the dealer). Having been in the automotive business I have seen this situation en-masse twice. Once was Nissan's first generation VQ35 engines which tended to have bad piston rings on cylinders 5/6 and once on Subaru cars running bad seals on the MHI turbochargers. In both instances I believe the OEMs calculated that it would be cheaper to tell customers excessive consumption was "normal" and to deal with the blown/damaged vehicles one by one rather than attempt to service all the problem vehicles. But this doesn't mean there isn't a problem and it doesn't mean the OEMs are being honest to owners.
Having owned quite a few performance cars and current vehicles include a nissan gtr and 911 turbo I've never experienced this amount of oil consumption in OEM trim - twin turbo or otherwise on "performance" engines. (dealer is trying to tell me M5 is a supercar motor heh) In fact the GTR and 911 turbo goes through half a quart every 3000 miles (granted with 2x less cylinders). Heck in modified applications where oil pressure was high and we used to get some blow-by on the turbocharger bearings or build the motors extremely loose on purpose it would be more unusual than not to consume a quart every 1000 miles.
I'd like to get some feedback on this from anyone else experiencing these problems. Does it get better or worse?
Blog about Pico and Micro Projectors!
www.micro-projector.com
      12-30-2014, 02:32 PM   #2
bobblehead
bobblehead's Avatar
Drives: warp speed
there are many threads that have covered this topic already.
for mine, 1 litre every 1000km was my norm. (??) started from day one.
      12-30-2014, 02:40 PM   #3
JR429
Thanks.
Wow that's a lot!
I just don't accept that as normal. Having owned a business that built quite a few (hundred) performance engines over the years this type of oil consumption isn't normal except on the loosest race engines. The BMW M5 isn't a race engine, it's a performance sedan that should act like one. There are MANY high power production cars that don't consume anywhere near 1 quart every 600 miles.
Anyone know where that oil is blowing through? The cold/hot expansion cannot possible be that aggressive that it's losing that much oil during warmup ???
      12-30-2014, 02:54 PM   #4
padrino
Alpina!
363
Drives: Alpina XB7
I go through about 2-2.5 quarts in 10K miles.. Same on both of my 2014 M5s...
2021 Alpina XB7 - Alpina Blue
2022 M5 CS - Frozen Gray
      12-30-2014, 02:57 PM   #5
bobblehead
bobblehead's Avatar
Drives: warp speed
Not much I can do. I know it's not thenorm. But dealer shop foreman checked out my complaint and called up BMW Germany to ask whether it's acceptable or not, the answer given to me was within acceptable limit as he showed up the service bulletin issued by BMW M division.
      12-30-2014, 06:13 PM   #6
PetrolFumes
Drives: Raptor, GT3RS,E92 M3,X5M50i
i put a quart every 2-3k miles
      01-14-2015, 05:58 AM   #7
Erik K.
Netherlands
Drives: BMW M3 Coupé e36 3.2
Accoording to BMW for M-engines 1,5 liter / 1000 kilometers is the limit.
If you're car uses more, it's not acceptable (by BMW)
For non M-engines the max consumption : 0,7 liter / 1000 kilomters.
BMW says you may only do a calcualtion after running at least 7500 kilometers.
      01-19-2015, 12:17 AM   #8
BIGW0RM
You got my money?
BIGW0RM's Avatar
Drives: Ice Cream Truck
2022 BMW M3  [9.50]
I notice it mostly on long drives. Thats when mine eats the most. Or at least it seems that way to me.
      01-19-2015, 12:55 PM   #9
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
I don't have an M5, but I don't buy it either. Had similar issues on a previous BMW and the dealer fed me the same story. The consumption continued to get worse with mileage. Good luck!
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      01-20-2015, 08:56 AM   #10
DrewM5
Drives: SG E60 M5
I had the same thing with my E60, but I think that is because the long drives cause the levels to be re-checked.
2014 M5 Competition|Space Grey|Black Merino Full Leather|Anthracite Trim|Executive package|LED Lighting Package|Drivers's Assit Package|B&O Sound System|Bel STiR Plus 9500ci|IND Side Markers and Side Vents|Exhaustmeister|HRE P101 Satin Charcoal/Michelin PSS (Summer)|601/Pirelli Sottozero Serie II (Winter)|Coded by V12
      03-28-2015, 12:50 PM   #11
saflang
Drives: 2013 M5
Just took my 2013 M5 in, it's been drinking oil since day one. BMW refuses to look at a new vehicle until so many kilometers (15000km I think). Anyhow oil top-ups are considered abnormal with less than 1200km/per fill. My fill-up this month was at just over 1000km. So now my dealership says they have found a 'puma notice' about a new valve cover gasket (from Germany) that provides better separation. No external oil leak was found so my gasket is on order and will be replaced in a few week. Fingers crossed I will no longer have to add a quart of oil every other gas fill-up.
///M5 2013
Singapore Grey with Silverstone
      03-28-2015, 02:56 PM   #12
patb23
patb23's Avatar
Drives: '14 M5 CP & '62 corvette
2014 BMW M5  [10.00]
1962 Corvette  [10.00]
I've had mine for about a yr and half (23k miles) and have never had to add oil.
2014 ///M5 Singapore Grey Metallic, Black Extended Merino, Anthracite Wood Trim, Comp Pkg, Driver Assistance Plus, Exec Pkg, Lighting Pkg, B&O, 343M Wheels (11.597 @ 122.44MPH)
Mods: Gloss Black Wheels, 35% 3M Tint, IND Gloss Black (LCI Grilles, Side Markers, Rear Emblem) IND M5 Floor Mats, RKP (McRae Splitters & Rear Diffuser), Passport 9500ci, Suntek PPF-C, M Door Projectors
1962 Corvette Convertible Red/Black (Gone:'11 750Li, '09 Z06, '08 550i)
      08-04-2015, 03:25 PM   #13
alienstudio
alienstudio's Avatar
30
Drives: F10 M5 CP | G05 X5 40i
I topped up 1 quart at about 5700km. It was also the first time I topped up since the 2000km break in service.
      08-26-2015, 07:24 PM   #14
Maverick997
Maverick997's Avatar
49
Drives: 2014 M5 Black Saphire Metalic
I have had no issues with excessive oil consumption at 12k miles. My E60 would use about 1 quart per 1000 miles. My Panamera used 1 quart per 1000 miles and it was also stated in the owners manual that would be the consumption. the green coalition has now driven auto manufactures to build engines with more clearance on rings to decrease emissions..... This leads to more oil,consumption....
Other toys
'07-997 Turbo....EVOMS 580..AWE exhaust...champion intercoolers..champion springs.
'91-964 Turbo K27 Hf turbo...Techart Exhaust...etc, etc
      08-27-2015, 12:49 AM   #15
gmfive
gmfive's Avatar
Drives: 2014 F10 M5 AW
2014 M5  [0.00]
Mine needed first oil addition at 7k miles. The 1qt left drip warning light came on.
2014 AW F10 M5, mostly stock
      08-27-2015, 01:32 PM   #16
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
Drives: 2013 BMW M5 | MSR Stage 3
This is a good document from BMW regarding oil consumption on our cars and others.
File Type: pdf SI B11 03 13 - Engine Oil Consumption.pdf (110.9 KB, 2380 views)
*** SOLD *** 2013 BMW M5 | Space Grey | MSR Stage 3 Tune | Catless Downpipes | MSR Intake and Charge Pipes | MSR Exhaust (Prototype) | Vorsteiner Rear Diffuser | RW Carbon Front Lip | RW Carbon Trunk Spoiler| Vorsteiner VS-310 Forged Wheels | Escort 9500CI w/Laser Jammers
      08-20-2016, 11:41 PM   #17
clubcsl
clubcsl's Avatar
Drives: M3 CSL,M5 F10,M4 CS, Z4 M40i
2003 BMW M3 CSL  [0.00]
2020 BMW Z4 M40i  [0.00]
2019 BMW M4 CS  [0.00]
2012 BMW M5  [0.00]
My car is also consuming a lot of oil.
I gave up trying to fix it.
www.clubcsl.com - I am a BMW Motorsport fan !
My youtube channel is here
      08-26-2016, 09:30 PM   #18
ur20v
Drives: F10 M5
This is normal - all manufactures have this 'issue'. Some cars use more or less.
BMW will not look at your car if your consumption is above the limit.
m5post
