10-02-2014, 01:45 PM | #1 |
Rep 118
255/35/19 square set up snow tires on Stock 19s
Hi Guys,
According to Tirerack, the Rim Range for 255/35s are 8.5-10 Our stock 19s are: 19x9 (front) 19x10 (rear) Is it safe to assume then, we can run squares with our stocks? |
10-02-2014, 03:03 PM | #2 |
Rep 353
Yes, already bought these exact tires. Mounting them on the M359s (same widths). The stretch at the back will look a bit silly but will be totally safe.
10-02-2014, 04:16 PM | #4 |
Rep 2,997
BMW sells the winter setup non-staggered in 18" size as their recommended 18" setup, so no.
AW/Carbonstructure 6MT 2015 M3 picked up 8/22/2014. Stripper except for adaptive suspension. Weighed at 3,450 pounds with 1/4 fuel. 70,000 miles as of February 2020.
10-02-2014, 06:23 PM | #6 |
Grand Poobah
Rep 186
Having the tires the same width really makes the most sense with the wheels the same as well. Are you going to rotate the 10in ones to the front at some point?
If you keep mounting and unmounting them to rotate, you're going to weaken and harm the bead. |
