08-11-2014, 10:43 AM | #1 |
Rep 500
Ride Quality - 18's versus 19's
How much is Ride Quality improved going with 18 inch wheels opposed to the optional 19 inch?
Would it be really noticeable - or pretty much insignificant difference? |
08-11-2014, 10:53 AM | #2 |
Rep 165
Drives: F82 M4 moonstone
I'm not a pro, but I'd say you'll notice the difference. had 18" on my 335 and then bought 19" for the summer tyres and yes, it was a noticeable difference. GF scratched them after 3 days, but that's another story.
I went for the black 19" on the M4 and will soon have to replace them (delivery of the car is due end of September, levaing me 1-2 months with summer tyres... just enough for run-in and then some) with the standard 18" with winter tyres. the 19" will then be back on by April 2015. on the other hand, I really like a "hard ride" (no pun intended) so I was absolutely fine with the 19" comfort. |
08-11-2014, 11:33 AM | #4 |
Rep 500
Yes - considering the same tire choice. If the daily driving ride quality is significantly stiffer with 19 inch wheels opposed to 18's, then perhaps 18's make better choice for daily driving?
However, if there is only a minor improvement going with 18's - then I prefer the look of the 19 inch wheels. I have little experience swapping out wheels - but know this is common practice for others on this forum. I was hoping to learn from their previous experiences. |
08-11-2014, 12:46 PM | #7 |
Rep 3,396
Seems as though a lot of high end performance auto manufactures have gone to 19s as standard, even as far as offering 20s as an upgrade. I ran 19s for 5 yrs on my 335i e92 with sport pkg and it was fine as a DD and it even had RFTs. But will say in winter situations 18s or even 17s will do best based on experience.
08-11-2014, 12:47 PM | #8 |
Rep 2,997
During my test drive, I noticed road irregularities that I believe were transmitted with NVH on the 19s that I BELIEVE would be eliminated with the 18s. The car still rode quite well, but I felt minor undulations and "busyness" that probably should have been dialed out but was not due to the lack of sidewalls.
From a daily driver and frequent driver standpoint, the 18s should ride better, wear slower, and cost less to replace. Lastly, one thing I'll note is that I spend the majority of my driving time (99.9% to be exact) on real world roads. These involve lots of unsmooth pavement. I find better traction and driving satisfaction out of vehicles that are able to better absorb mid-corner road undulations without upsetting the chassis. The M3 has the best chassis to date, but a bit of give can actually improve performance in these situations and I think the 19s take a bit of that give away. Just my .02 and based solely on a very good test drive. Edit: Just to be clear, after seeing some other comments, this isn't about 18s vs 19s. It's about sidewall height and construction. It's not the 19s are inherently some lesser design, it's that by going to 19s you get a significantly more rigid sidewall that is 33% (IIRC) smaller in height. |
08-11-2014, 12:54 PM | #9 | |
Rep 3,396
08-11-2014, 12:59 PM | #10 |
Rep 2,997
Don't forget that the 18" wheels are notably less weight than the 19s (I can't comment on tires since IDK and tirerack is not accurate). I believe it's 3.3 pounds per wheel in the front and ~2.3-2.6 pounds per wheel in the rear.
08-11-2014, 01:17 PM | #11 |
Ring Leader of G8X Trolls
802
Rep 1,762
The 18 will be more comfortable. 19 are a good compromise between looks and performance, with that said I'm very please with design and weight of the standard 18's and optional 19's.
08-11-2014, 01:22 PM | #12 |
Rep 38
FWIW, I gotta say, on the 19s I *really* feel how crappy the roads are in NYC, in a way I didn't expect. I'd love the feel if we had good roads, but it amplifies the bad roads here in a major way I didn't expect.
08-11-2014, 01:37 PM | #13 |
Rep 3,396
Whatever choice you make, 18 vs 19, you have to like the idea the 18s are forged, looks quite good and are a standard offering, ie not extra cost!
08-11-2014, 01:49 PM | #14 |
Rep 49
...but how much are the 18" tires vs the 19" tires?
08-11-2014, 03:43 PM | #15 |
Rep 2,997
Here's all the weight info I could pull together quickly:
18” http://f80.bimmerpost.com/forums/sho...php?p=16426788 Front: 44.00lb w/ tire Rear: 48.25lb w/ tire 19” wheel and tire: http://f80.bimmerpost.com/forums/sho...el+tire+weight Front = 45.90 w/ tire Rear = 49.85 w/tire Weights of Rims per BMW: http://f80.bimmerpost.com/forums/sho...php?p=16426788 18" 513M front = 8.92kg (19.6lbs) rear = 9.44kg (20.8lbs) 19" 437M front = 10.4kg (22.9lbs) rear = 10.6kg (23.4lbs) |
08-11-2014, 04:03 PM | #16 | |
Rep 49
08-11-2014, 04:27 PM | #17 |
Rep 2,997
Yep, no problem. It's funny, heavier tires are definitely not what you want from a performance standpoint - but I'm willing to bet that weight is going into an outstanding carcass and sidewall that will hold up better to abuse AND absorb better imperfections.
Though the total unsprung rotating mass is less with the 18s, I'm betting the fact that the 18s tires are heavier will balance it out considering they are a greater distance from the axis. |
08-11-2014, 05:15 PM | #18 | |
Rep 500
My car will be a daily driver and never see the track. I currently have Black 19's on my order. For everyday comfort - I wonder if the 18's are a better choice. |
08-11-2014, 06:05 PM | #19 | |
Rep 49
08-11-2014, 09:08 PM | #20 |
Rep 2,997
08-11-2014, 09:25 PM | #21 | |
Rep 2,997
The 19s are a very nice option for visible purposes or CCB upgrades. |
08-11-2014, 11:14 PM | #22 | |
Rep 49
Back to F8X specific stuff! |
