07-30-2014, 09:46 PM | #1 |
2015 M4 Coupe, Black Sapphire
31
Rep 145
Wheel bearings
My front wheels are clicking & ticking constantly now. For the last two weeks it was just when I was turning at higher speeds...now the sounds are coming when I'm going straight and turning constantly.
Anyone else having this issue? |
07-30-2014, 09:51 PM | #2 |
Commander-In-Chief
2122
Rep 8,924
Drives: 2023 M2 Coupe, 2020 GLE 450
haven't seen anything. Not a rock or nail in your tire? Lift wheels and try free turning.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
07-30-2014, 09:53 PM | #3 |
Large Member
951
Rep 1,749
Someone else here was having that issue. Or was this your second thread regarding the bearings clicking? I know I read someone else posting about clicking bearings within the last 2 days.
2008 E92 M3 (Engine swap completed), 2015 F82 M4
07-31-2014, 06:24 AM | #4 |
Rep 991
Drives: 2015 BMW M4
07-31-2014, 07:04 AM | #5 |
Rep 1,282
Classic bearing failure noise is grinding when turning. Doesn't seem to be what you describe.
M850i Vert with RaceChip
E46 M3, Euro Headers, Rasp Pipe, Kassel Tune Alpina B8, zero performance mods |
07-31-2014, 08:00 AM | #6 | |
Rep 6,701
Wheel bearings are a groaning noise that is usually present at all times. It sounds like worn out tires or mudder tires with a big treat. Hummmmmm. But unlike worn tires, where pitch increases with speed, failed wheel bearing noises increase volume as speed increases. It starts out quiet, only present when that wheel is loaded in a turn, and as it fails worse, it is present at all times, louder when that wheel is loaded, quieter when wheel is not loaded. Sounds like something else on your car. |
07-31-2014, 07:49 PM | #8 |
Rep 11,760
Drives: 2018 M4 Comp Indv
Yeah I'd find a tall curb or a fence close to the road where you can roll down your windows and drive really slow to see if you can isolate the click sound - if it's a rock or nail you should be able to roll just past it, stop, and find it. You should also be able to isolate which side and which tire(s) for the sound.
08-01-2014, 07:11 AM | #9 | |
Rep 2,176
08-01-2014, 09:52 AM | #10 |
31
Rep 145
It's not a rock or a nail. It is the hub assembly for sure. The sound increases with speed and with load. I'm taking it in for service today. I'll keep ya posted on what it is.
These sounds are driving me nuts! Do any of you know if the exhaust flaps will stay open if you unplug the cable going into them while they are in the open position? |
08-26-2014, 10:29 AM | #12 |
Rep 1,469
At least its not the dreaded "cow bell" sound that the e9X suffered from. Made it sound like you were "just married" when driving down the street.....
Lambo Huracan, Cherokee SRT, C8 on order.
Sold- 458, GT3, f80 M3, e82 1M, f87 M2, e30 M3, e90 M3, e36 M3, e34 M5, e36 M3, e30 M3........ |
08-26-2014, 04:18 PM | #13 |
Rep 480
I have a loud metal on metal sound when turning during weight transfer (e.g. braking downhill and turning sharp). Hard to say where it's coming from, probably parking brake.
09-03-2014, 09:20 AM | #14 |
Rep 489
UPDATE on this issue. My dealer could recreate my clicking noise. He said its exactly the same that the F30 has a TSB for right now (some swivel joint). He ordered the parts and i should have her fixed shortly.
2020 M2C.
09-16-2014, 10:19 PM | #16 |
Rep 2,286
Was this sound for you guys one where the frequency of the sound increased directly proportionate to speed? Sounds like something rubbing with each wheel revolution - which would explain why the sound increases/descreases exactly proportionate to speed.
Also - after approx. 10 minutes of driving, I was able to get the sound to initially go away completely when going straight or turning wheel to the left - but sound remained when turning wheel to the right. Approximately 20 minutes later, I was able to get the sound to go almost completely away regardless of going straight, turning left or right. Toward the end of the drive (about 40 minutes total) the sound only occasionally came back (sometimes after going over slight bump in the road) and then go away again... If the sound keeps coming back after a few days then I'm going to bring it in as well... |
09-17-2014, 09:49 PM | #17 |
Rep 547
My car was in the shop for the past two days for a clicking noise from the passenger front tire and rattling noise from the exhaust. Dealer is ordering a wheel bearing. They cleaned the bearing and the noise increased. They are also replacing the exhaust system.
