06-23-2014, 06:15 PM | #1 |
Rep 428
Oil change thread
2010 BMW 128i and I am at 7,000 miles since last oil change.
Any tips? I have changed all my other Bimmers but never a e82. Thanks for looking and helping. |
06-23-2014, 06:56 PM | #2 |
Rep 374
The stickied thread by JimD helped me a lot when I did my first oil change.
http://www.1addicts.com/forums/showthread.php?t=301440 I believe the socket sizes you need and the torque spec for the oil screw are all there. Even suggestions for various tools to open the oil filter cap.
New Car: 2019 Porsche 718 Cayman GTS | Stock for now Old Car: 2013 BMW 128i | 6MT | BMW Performance Grills | CDV Delete | SSK | Performance Exhaust | M3 RSFB | TCKR DA |
06-23-2014, 07:35 PM | #3 |
1Addict
3239
Rep 7,906
I'll throw this piece of advice in here:
#1 Get an oil filter cap wrench attachment. I have a volvo cap wrench and it works fine (just get the right size), figure same thing as the BMW specific sockets just without the BMW tax. I used a rubber strap wrench the first time, and it just didn't satisfy me. I also broke one of the strap wrenches. You don't have to spend $40 on the filter wrench, but definitely get one, it makes things so much easier. #2 Take your time properly lubing and placing the filter o-rings in. It's easy to do it right, but also easy to do it wrong. It might try to slip on you as you start threading the filter cap on. Just watch for that and adjust the o-ring as necessary.
06-23-2014, 08:49 PM | #5 |
Rep 64
I tried the Volvo spec cap wrench from Pep Boys but had to return it because it kept slipping and a strap wrench was useless. BMW seriously over tightened the cap. Bought the tool from BavAuto and it worked fine. Much heavier gauge and did not flex & slip when loosening the over torqued cap. Already had the 7mm socket for my wife's 530
06-23-2014, 09:22 PM | #6 |
1Addict
3239
Rep 7,906
^^ There are at least 3 different sizes that I have seen for Volvo wrenches. That might have been your problem.
06-23-2014, 11:15 PM | #7 |
bimmerphile, technogeek
1000
Rep 3,785
Drives: 2012 E82 6MT Sport
The oil and filter change is a piece of cake.
06-24-2014, 10:44 AM | #8 |
Rep 2,280
The drain plug is a wimpy little thing and one need go absolutely straight on and best to use a 6 point socket. Now, real oem states that a new drain plug be used with each oil change. I just found this out. I'll probably change it out with every 2nd oil change. Another and better alternative would be the magnetic drain plug sold by Bav Auto. Its made by Dimple and a few others here use it and its of very high quality and can be reused indefinitely.
06-24-2014, 11:06 AM | #9 | |
European Editor
10628
Rep 22,992
