06-17-2022, 08:03 PM | #1 |
Rep 515
Radar Detector Mounts
Anyone running radar detectors and can share their experience with how it is mounted and share some pics?
Blendmount, in my opinion, makes the best mirror mounts on the market. On my C7 Corvette, I had a Blendmount with a Uniden R3. It was an awesome combo being that the radar detector itself was on the smaller side and there was no need to access the mirror bottom. So it was placed directly underneath the mirror and had a stock appearance. My concern with the G82 is it seems you need access to the bottom of the mirror so I don't think a mount would look aesthetically pleasing. If you feel otherwise, and have a photo, please share. I think the sweet spot would be the highest point on the windshield just left of the mirror. I did some research, and those black dots (called frits) will not effect performance. Anyone else have other ideas and/or photos for an effective mount? FYI. I'm looking into the Valentine V1 Gen 2. Thanks. |
06-17-2022, 08:12 PM | #2 |
Rep 1,534
Drives: '22 Mexico Blue G80 xDrive, '2
Blendmount and wire tap looks great and works well on our cars. I used it with my uniden R7. It looks clean.
06-17-2022, 10:04 PM | #3 | |
Rep 726
Part #'s: BR7-2036 Blendmount MTX-1015 Mirror Tap There is this thread as well... https://g80.bimmerpost.com/forums/sh....php?t=1878835 |
06-17-2022, 10:53 PM | #4 |
Rep 492
+1 for blendmount very happy on my r7.
comebackid289.50 Limegrntaln13469.00 |
06-17-2022, 11:07 PM | #5 | ||
Rep 515
m4ml1834.00 |
06-17-2022, 11:11 PM | #6 | |
///M ♥ Recycled Dinosaurs
3197
Rep 1,775
Drives: BMW M4, BMW X5 45e
Also, there is not interference from gesture control in the M4. It sometimes randomly happens in the X5 and goes away with minor adjustments (front to back of the detector). I was dreading problems requiring taping up the IR blaster for gesture control but didn't need to.
comebackid289.50 |
06-17-2022, 11:41 PM | #7 | ||
Rep 515
So is the port alone a sufficient power source? |
06-17-2022, 11:52 PM | #8 | |||
3197
Rep 1,775
https://www.valentine1.com/v1-detectors/savvy/ It works fine with the Gen 2. eSavvy is a software feature in their mobile app as far as I can see and obviously can't be a power source. I think it uses GPS on your mobile phone and relays speed from that to your V1 through Bluetooth. I don't think that is a good enough alternative unless you really want to mirror tap.
comebackid289.50 |
06-18-2022, 11:46 AM | #11 | |
Rep 217
06-19-2022, 01:30 PM | #12 | |
Rep 609
06-19-2022, 04:55 PM | #13 |
Rep 609
Actually, thanks to the Valentine/Savvy comments, I found the solution I was looking for on my Escort mount. I hate having the beautiful carbon fiber cover open to use the 12v outlet in the cup holders. I bought a OBD connector for 12 volts from it, and a hard wire Escort connector. Will plug one into the other for $48 and solve my problem! Would not have known this was possible without this thread! Gotta love the Forums!
06-19-2022, 07:06 PM | #14 | ||
3197
Rep 1,775
06-20-2022, 05:21 AM | #15 |
Rep 222
Valentine Gen 2 with blendmount and Savvy OBD power supply
comebackid289.50 |
06-20-2022, 10:43 AM | #16 |
9052
Rep 7,621
I'm clearly in the minority here, but I don't like the look of something hanging below the mirror. I'd much rather have it tucked in the left lower windshield. I accept that this location is not at sensitive as if its high up in the window, although I might wonder how much of a distance 2ft really makes. The rub for me is that in my F82 there was the 12v outlet in the passenger footwell so I could have 1 to power the RD and another to power the phone charger. I just ran a cable across the top of the steering wheel over to the side of the window and it was actually tucked fairly out of the way. There wasn't a great way to do that though with the G82 setup. I'm considering doing the mirror tap and then running a cable tucked in along the top and side edge of the window to the left lower corner.
comebackid289.50 |
06-20-2022, 11:23 AM | #17 |
Rep 515
Thanks for sharing.
Is there any more wiggle room to raise the detector higher so you can see less of the blendmount from the bottom of the mirror. My goal is to have it flush with the bottom of the mirror but still needs to be further back to access the buttons at the bottom of the mirror. |
06-20-2022, 11:32 AM | #18 | |
Rep 222
06-20-2022, 02:29 PM | #19 | ||
Rep 515
06-20-2022, 02:39 PM | #20 |
Rep 193
Blendmount here as well with my Valentine Gen 2. I do have a Uniden blendmount for sale in the interior parts section if anyone is interested(BR7-2036).
06-20-2022, 08:29 PM | #21 |
Rep 217
06-21-2022, 06:02 AM | #22 |
Rep 222
It's a flat wire. It is not visible if run properly behind the interior trim around the window and A Pillar.
