07-22-2023, 02:38 PM | #1 |
Rep 133
Wheel Damage - What are the odds of this happening?
I went for a quick drive earlier and out of nowhere heard an awful grinding noise. I immediately pulled over and looked at the driver side front wheel and immediately saw the damage below. It took a minute to figure out what was going on then saw the culprit. A small rock, that got stuck between the caliper and wheel. Luckily no damage to the CCB caliper from what I can tell but the wheel is a mess. I know it could probably be repaired but I haven't even hit 500 miles yet so I will be replacing it (already ordered). I've had several cars with calipers in close proximity to the wheel and never had this problem. I also have the car fully wrapped in Xpel and the windshield in Exoshield, and this is where that one rock still causes damage...
07-22-2023, 03:18 PM | #2 |
Rep 184
Drives: F90, G80
My F80 CS wheels have this issue ALL THE TIME in the front. There is literally a MM of clearance, and both sides are fully destroyed like that. First time happened within a week of owning them. I've recoated the wheels several times, and each time a rock finds its way in. Never any damage to the caliper either.
07-22-2023, 03:32 PM | #3 |
///M ♥ Recycled Dinosaurs
3209
Rep 1,777
Drives: BMW M4, BMW X5 45e
You're replacing the wheel for this? A wheel repair shop could make quick work of this easily. They can make easily visible damage disappear. This would be a cake walk.
07-22-2023, 04:49 PM | #5 |
6920
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
Why replace it. Throw some paint on it and now you have an extra mil of clearance for the next rock.
07-22-2023, 05:40 PM | #6 |
Rep 506
Have had this happen to me as well. Front driver’s side wheel. Drove over a patch of gravel on the road going 60 mph or so and immediately heard an aweful grinding sound. I pulled over initially thinking I had a flat. After a couple minutes it worked itself out.
07-22-2023, 07:08 PM | #7 | |
Rep 133
07-22-2023, 07:10 PM | #8 |
Rep 6,726
Very common on the F80’s.
StephenWyker316.00 |
07-22-2023, 11:41 PM | #9 | |
Rep 218
07-23-2023, 01:29 PM | #10 |
Rep 133
If it happens again I think a 20" squared setup might be the answer.
MaC-N54-E82479.00 |
07-24-2023, 02:26 PM | #12 |
Rep 470
Happened to my 437M wheels on my M2C. Very common with the big brakes on that car, or any M3/M4 CCBs unless you get the 20"/21" kit.
previous BMWs: '02 M3 6MT, '17 M240ix, '19 M2C 6MT
