      08-13-2022, 08:53 AM   #67
mydxb
Drives: M4
Originally Posted by FISH22 View Post
Those should fit just fine, OE front is 19x9.5 +20. If you do run into brake or shock clearance, as those are a few mm higher than OE, you could easily run a spacer to push them out.
which spacer size mm do you recommend?
      08-13-2022, 09:35 AM   #68
FISH22
FISH22's Avatar
Drives: G80 M3 Competition
2021 BMW M3C  [10.00]
2011 BMW M3  [10.00]
For context, I've been running the 963M (19x9.5 +20) on the front with 18mm spacers for a while now. My G80 is also lowered on KW HAS. Occasional rubbing while reversing. So you can easily throw a 10mm spacer on the front, or maybe more, depending on your tires and ride height.
See photos. This is the current setup described;
mydxb59.00
      08-13-2022, 09:39 AM   #69
mydxb
Drives: M4
nice ride! thanks for the info much appreciated
FISH225404.50
      08-13-2022, 09:55 AM   #70
FISH22
FISH22's Avatar
2011 BMW M3  [10.00]
Thanks, and no problem!
mydxb59.00
      08-13-2022, 02:14 PM   #71
FISH22
FISH22's Avatar
2011 BMW M3  [10.00]
If anyone is wanting a diamond black G8x set, go ahead and grab those gloss black ones from Australia and we'll trade
(Gloss black was my first choice)
      08-15-2022, 06:34 PM   #72
FISH22
FISH22's Avatar
2011 BMW M3  [10.00]
Woot woot.
Appreciate 9
MMM.PWR3452.00
M4_lgnd403.00
Ariboon379.50
pinky_chi172.00
mydxb59.00
BrockDM2043.00
Sean@PSI2135.50
      08-15-2022, 09:27 PM   #73
M4_lgnd
M4_lgnd's Avatar
403
Drives: 2022 G82 M4
Which tires you going with and size?
2022 G82 Signal Green M4 Competition XDrive
      08-16-2022, 04:47 AM   #74
FISH22
FISH22's Avatar
2011 BMW M3  [10.00]
Will be keeping my current 285/30 4S to throw on the front, and then going with either a 295/30 or 305/30 for the rear.
      08-16-2022, 09:54 AM   #75
Ariboon
Drives: 23 BGM M3C xdrive
+1. Will be running 285/30/20 and 295/30/20 since mine will be xdrive and need to be within 1%.
2023 Brooklyn Grey Metallic M3 Competition xDrive
Build Progress IG: @g80_arie
      08-16-2022, 05:41 PM   #76
MMM.PWR
Sith Lord
Drives: G80X, Mazda 3 6MT (daily)
So jealous of you guys. I like bronze the best, I am sure they do not have it anymore. But I don't mind waiting as I don't plan on getting wheels for a while. I've ALWAYS wanted Volks. Kind of torn between the GT090 and the TE37.
Always two there are.
Ariboon379.50
      08-17-2022, 12:35 AM   #77
Ariboon
Cant go wrong with either (PSI's build prior to the titan 7 and wraps looked great in IOMG and GT090)! I too have always wanted volks; I saw my shot and took it haha.
MMM.PWR3452.00
Sean@PSI2135.50
      08-17-2022, 09:37 AM   #78
mydxb
Drives: M4
just to let you know TE37 19x9.5 +20 fits front of g82
Ariboon379.50
      08-17-2022, 01:26 PM   #79
timstah
Drives: A90 Supra, G80 M3 comp xdrive
I put a 10mm spacer up front on the G8x TE37 spec'd ultra-Ms for flush flush fitment. It rubs against the fender liner fins, but otherwise looks great
      08-17-2022, 01:38 PM   #80
timstah
10mm spacer in front
Ariboon379.50
FISH225404.50
      08-17-2022, 03:14 PM   #81
Ariboon
looks good tim! scared to ask how much fender liner trimming / molding you needed to do. Or did you just chop off the fins and were good?
      08-17-2022, 04:13 PM   #82
MMM.PWR
Sith Lord
You think 12mm would be too much? I have 12mm with the OEM rears currently.
Oh yeah, I guess I should mention that I pulled the trigger on the flat black set. Thanks to this thread... at last, I will have Volks. Where's everyone buying tires from? I'll move the rears with 2500 miles to the front.
Ariboon379.50
FISH225404.50
      08-17-2022, 04:24 PM   #83
Ariboon
I think the 12mm may be require some major fender liner cutting but I would also like to hear Tim's experience with the 10mm up front. I am planning on throwing on a 5mm spacer up front to achieve the 15mm spacer + oem wheel look.
https://g80.bimmerpost.com/forums/sh....php?t=1913236
Regarding tires, there no PS4* in 295s but, tirerack has PS4 blackwall 295s in stock early september.
MMM.PWR3452.00
FISH225404.50
      08-17-2022, 09:38 PM   #84
MMM.PWR
Sith Lord
Are you guys just swapping over your stock TPMS sensors? I'm assuming no issue with running OEM PS4* up front and the PS4 blackwall 295s in the rear?
      08-18-2022, 05:47 PM   #85
FISH22
FISH22's Avatar
2011 BMW M3  [10.00]
Awesome!! My original order with vivid was for the flat black, but switched to DB.
MMM.PWR3452.00
      08-18-2022, 05:49 PM   #86
FISH22
FISH22's Avatar
2011 BMW M3  [10.00]
I'm swapping OEM sensors over.
And non-issue to run different blends of 4S's on different axles. From what I've read, it's advised to not have different compounds of the 4S on the same axle.
      08-18-2022, 05:54 PM   #87
timstah
you could definitely get away with 12 in the front.
I actually upped it to 13mm. (I did have to trim the "L" on the front fender that protudes inwards) - I shaved it.
FYI for those who dont know...my specs are 20x10 +15 (+2 with 13mms spacer), and 20x11 +15 (no spacer in rear). I have about -1.9-2.0 camber all around)
285/30/20F, 295/30/20R (xdrive)
I haven't shaved the fins yet...it only rubs on reverse at more than 45 degree angle. Im going to investigate this this weekend!
      08-18-2022, 09:39 PM   #88
MMM.PWR
Sith Lord
I plan on doing the same. I ordered two 295/30/20 4S's from Discount Tire today. Also ordered black center caps with the red Rays logo from Evasive. And I ordered a stud conversion kit (75mm) and some lug nuts. from IND. All that is left now is to dismount tires and swap sensors, and then I'll get the wheels ceramic coated. Once all this is done, then I will see what spacers I need to replicate my existing OEM look with 15F 12R spacers.
What's the status on your wheels? I know you received them. Mine should be here on Sunday.
Thanks for the information. I will definitely move my 12mm spacers up front then. What is this "L" piece on the front fender?
