04-07-2022, 07:06 AM | #1 |
Rep 290
Aftermarket wheel offset selection guide
Hi Lads,
There's countless posts here by people not understanding offsets, and asking what offset is ideal for aftermarket wheels, so I thought I'd put two and two together to offer a guide. The first step is to look at the thread which IND spacers put together and work out the ideal amount of poke for you: https://g80.bimmerpost.com/forums/sh....php?t=1808816 Note, I have no affiliation with them or any merchant, I'm posting it as a reference as its a very well put together and helpful thread - props to the IND guys for the time they took. Just keep in mind if you plan on running a 20 inch wheel at the front, the more aggressive offsets (lower ET number) may give you clearance issues with the inner guards. There's plenty of talk here on what to do about that - most people that rub, trim them. Step 1 is to decide how aggressive you want to go, step 2 is selecting your wheel width to achieve that look. Also note, that if you follow this guide you shouldn't have clearance issues unless you go crazy with tyre width on a given rim size. The guide assumes tyres are well matched to rim width. *Only caveat is the equivalent to an 18mm spacer on the back, I think these offsets could be too much when lowered on the rear. If you like the look of 5mm spacers on factory rims, your offset for aftermarket wheels should be: Front: 9.5 inch rim - ET15 10 inch rim -ET21 Rear: 10.5 inch rim - ET15 11 inch rim - ET21 If you like the look of 12mm spacers on factory rims, your offset for aftermarket wheels should be: Front: 9.5 inch rim - ET8 10 inch rim - ET14 10.5 inch rim - ET20 (note this will have very little clearance inside) Rear: 10.5 inch rim - ET8 11 inch rim - ET14 If you like the look of 15mm spacers on factory rims, your offset for aftermarket wheels should be: Front: 9.5 inch rim - ET5 10 inch rim - ET11 10.5 inch rim - ET17 Rear: 10.5 inch rim - ET5 11 inch rim - ET11 If you like the look of 18mm spacers on factory rims, your offset for aftermarket wheels should be: Front: 10 inch rim - ET8 10.5 inch rim - ET14 Rear: 10.5 inch rim - ET2 11 inch rim - ET8 (outer guard clearance may be an issue if running a 295 - 305 sized tyre. Last edited by BulkBen; 05-01-2022 at 06:43 AM.. Reason: Post u[dated to add a few more 10.5 inch front options, also note about running an 11 inch rear with a large offset. |
15
04-07-2022, 04:01 PM | #2 | |
Rep 2,368
Formerly Wyndi335I
04-07-2022, 06:56 PM | #3 |
Rep 6,961
I would think if I was going to spend $5-$10K on a set of wheels, I wouldn't want any spacers. Why would you want to install spacers, if you were getting a custom set of wheels, for your car?
JDUNITNOW Everytime I hear someone who likes poke, I cant help but to think...
YT: G Dubyou |
04-07-2022, 08:54 PM | #4 | |
Rep 2,368
Formerly Wyndi335I
Limegrntaln13469.00 ROBERT11831569.00 |
04-07-2022, 10:13 PM | #5 | ||
Rep 6,961
YT: G Dubyou |
JDUNITNOW3511.50 ROBERT11831569.00 |
04-08-2022, 04:28 AM | #6 | |
Rep 290
The spacers thread is referenced simply so you can decide how you want your car to look after you put aftermarket wheels on it - without spacers. Once you decide how much (or how little) poke you want, you decide on your wheel width, then you match the offset number. For example, if I love the look of 15mm spacers (on stock rims) at the front and want 10 inch front rims I'd go ET11. If I plan on putting 11 inch wheels on the rear and like the look of 12mm spacers at the rear, I'd go ET14. There are so many posts here from people asking about fitment and aftermarket rims, so the guide helps them match the offset they need to achieve the look they want |
04-08-2022, 04:33 AM | #7 | |
Rep 290
If you like the look of 15mm spacers on factory rims, your offset for aftermarket wheels should be: Front: 9.5 inch rim - ET5 10 inch rim - ET11 If you like the look of 12mm spacers on factory rims, your offset for aftermarket wheels should be: Rear: 10.5 inch rim - ET8 11 inch rim - ET14 |
JDUNITNOW3511.50 |
04-08-2022, 05:45 AM | #8 |
///M-Thusiast
3634
Rep 936
Drives: '23 X5 M50i
What is a wheel?
Current: 2023 G05 X5 M50i xDrive
Soon: 2024 G87 M2 Past: G80 M3x, G80 M3, G05 X5, F82 M4, F87 M2C, F20 M140i |
JDUNITNOW3511.50 Skyscraper2196.00 |
04-08-2022, 10:24 AM | #10 |
Rep 2,368
Damn, can't wait to see them. I want bronze but ambsxarwd I will get tired of the color soon. Never ventured outside of a Siler type wheel ever. My first time with a black wheel and I somewhat regret it. It stays dirty looking and the 826m is a bitch to clean.
Formerly Wyndi335I
04-08-2022, 01:14 PM | #11 |
Rep 989
Yeah the 826m wheesl are a pain to clean. The HRE 305 will be easier to clean. I will probably swap out my pads at some point to help with the brake dust.
IG:F80M3ROB
NEDC member |
04-08-2022, 02:07 PM | #12 |
Rep 2,368
Most definitely, I already did mine when I got my car. I've been happy with the outcome and the dust from pads are about 60% less than oem. This is after one week of driving. Keep in mind, I may put about 200 miles or less on my car weekly. I have multiple vehicles and also work from home most days.
Formerly Wyndi335I
04-12-2022, 11:18 AM | #13 | |
Rep 2,368
What tire sizes are you sticking with? I want to swap my 285 to the front and going with Eibach springs for minimal drop. Wouldn't you have to adjust for wider tire so it will not poke at top of fender or will it still be flush with your et?
Formerly Wyndi335I
04-15-2022, 09:52 PM | #14 | ||
Rep 989
IG:F80M3ROB
NEDC member |
JDUNITNOW3511.50 |
04-28-2022, 11:33 AM | #15 | |
Rep 124
Drives: 2021 BMW M4
BulkBen - awesome post man. Not sure if you can pin on these forums but this one deserves to be pinned imo. |
05-01-2022, 06:36 AM | #16 |
Rep 290
Thanks mate, yeah I had hoped it was helpful but its taken a while until someone has seen some value in it!
With so many people confused about widths and offsets it should help. |
05-08-2022, 12:11 PM | #17 | |
Rep 1,496
2022-G80 Xdrive BG
2014-GTR BE FBO 2016-HURACAN 610-4 (SOLD) 2021-G82 BASE (SOLD) |
05-08-2022, 03:17 PM | #18 |
Rep 2,368
I went with Dynamic Friction 3000 brake pads and have been very happy with them. Parts Geek and Buy brakes.com have them. Also Ben at RG Sport has a set of brakes in development I understand will be great also.
Formerly Wyndi335I
05-12-2022, 05:48 PM | #19 |
Rep 32
To the Original poster @BulkBen
Thanks for posting this. Thus guide is a lifesaver. I am getting wheels, hopefully in the near future and this saved me a ton of time researching the right fitment. I bookmarked and screenshot your post. Salute |
08-05-2022, 05:00 PM | #20 |
Rep 119
Thanks for posting @BulkBen…helpful.
I’m new to aftermarket wheel offsets, but trying to match the ‘look’ of another members setup with a set of wheels I like best that has a ET22 minimum. Hoping you all can check my logic and tell me if the two scenarios will give the same ‘look’: Front: 20x10.5 ET15 no spacers = 20x10.5 ET22 w/ 7mm spacers? Rear: 20x10.5 ET15 w/ 10mm spacers = 20x10.5 ET22 w/ 17mm spacers? Thanks in advance.
2023 M3 Comp XDrive
2018 Tesla MX Performance 2015 BMW M3 2013 Audi RS5 2010 Nissan GTR |
08-05-2022, 06:33 PM | #21 | |
Rep 290
What tyre are you wanting to put on the front with the 20x10.5 ET15 no spacers? You should be ok with a 285, but 295 may be pushing it as there isn't much inner clearance from rim / tyre to the strut. This is very similar offset to what I am about to run, but as I am going a 305 all round for the track I expect I'll need at least a 10mm front spacer. |
08-05-2022, 09:32 PM | #22 | |
Rep 119
2023 M3 Comp XDrive
