08-08-2022, 12:29 PM | #1 |
Rep 467
Turn on "M Mode" with M1 button?
I was fiddling with my car last night (gawd, I love this thing) and set up my M1 and M2 buttons, but I can't seem to get the car into sport "M Mode" with just one press of the M1 button.
I have to touch the M1 button AND the "M Mode" button on the center console. Does anyone know if this is possible? And WOW the car transforms when put into all the kick arse modes! |
08-08-2022, 01:25 PM | #2 | |
Rep 2,303
2001 330Ci (sold)
Limegrntaln13473.50 |
08-08-2022, 01:48 PM | #3 |
Rep 3,407
Agreed. Slightly annoying. Thankfully, the “M Mode” display isn’t all that special.
Would be nice if there was another mode which would display traditional looking gauges like in the F80/F82. |
08-08-2022, 02:03 PM | #5 |
Rep 2,164
jimbethesda1856.00 |
08-08-2022, 02:50 PM | #6 |
Rep 375
08-08-2022, 02:55 PM | #7 | ||
Rep 3,407
Will they? No. |
08-08-2022, 03:12 PM | #9 | |
Rep 2,303
2001 330Ci (sold)
jas1651448.00 |
08-08-2022, 03:38 PM | #10 |
Rep 14,115
Drives: G82 M4C X-Drive
I wish TRACK MODE was more simple as well. Holding down the button is a small inconvenience, but my routine for track days has enough steps already:
M2, lower windows, power up the gopro, turn on lap timer, hold down the M mode button for track mode, turn iDrive screen back on, scroll to tire pressure page, put on helmet, put on gloves.... anything to reduce that helps when you're trying to grid.
calbears4251.00 Achtung_M329.00 |
08-08-2022, 03:42 PM | #11 |
Rep 2,489
Drives: 2018 F80 M3 CS,2017 F87 LBB M2
The noise control has been there in the M1/M2 configuration since launch
2018 F80 M3 CS
2017 M2, LBB, DCT, exec, car play, MPE, diffuser 2011 E90 M3 ZCP Past: E90 328i, F10 535i, F80 M3 (murdered) |
08-08-2022, 03:45 PM | #12 | |
Rep 2,489
and you can also set a hotkey for the tire pressure monitor system, which is what I have set up in my F80
2018 F80 M3 CS
08-08-2022, 03:48 PM | #13 |
Sith Lord
3452
Rep 893
Drives: G80X, Mazda 3 6MT (daily)
I turn it on every time I drive because it's a lot easier to see the RPMs and I tend to use my paddles a lot.
Always two there are.
jimbethesda1856.00 BEAR-AvHistory3128.50 |
08-09-2022, 11:44 AM | #14 |
Rep 286
Picked up my latest BMW since a '72 2002 Tii on Saturday and the M-controls not working with the M-mode is the most frustrating thing so far.
Programming M1 and M2 is also frustrating because you think you have made a change and some things just do not work. iDrive should provide feedback when you are trying to enter conflicting choices. As an ex software engineer, I embrace the philosophy that user friendly programming is competent programming.
BMWs: ' 24 M4Cx cvt, '22 M4Cx, '72 2002 Tii; MBZs: '18 C63s coupe (EuroDeliv), '07 SLK55, '01 CLK55; Jag XKEs: '67 roadster, '65 coupe; '74 Jensen Healey
NorCalAthlete3191.00 |
08-09-2022, 01:29 PM | #15 | |
Rep 320
I'd prefer more configurability of the displays across the modes. |
08-09-2022, 01:44 PM | #16 |
Rep 61
Personally I find that the standard mode rpm is more accurate because the line is longer. It's easier to shift gears just at the right time. The presentation of the sport mode is more good looking but the vertical lines are short.
08-09-2022, 02:35 PM | #17 |
Sith Lord
3452
Rep 893
I haven't really tried using them as all our cars have a HUD (even little old Mazda has the little flip up plastic) and if I look down it feels like I am not looking at the road. Will try it though.
08-09-2022, 03:53 PM | #18 |
///M
1610
Rep 296
I started a thread around getting the Sport HUD to be programmable by the M1 and M2 buttons. In my F82 I was able to configure the preferred HUD directly into the buttons, but for whatever reason BMW changed that and only allows the Sport HUD if you press the damn M mode button.
https://g80.bimmerpost.com/forums/sh....php?t=1856760 It's not difficult to hit M1 and then hit the M Mode button, but doing so means you lose the Road instrument cluster to enable the better HUD. Annoying.
08-09-2022, 04:15 PM | #19 | |
Rep 467
Also a good point. |
BugKiller291.50 |
08-09-2022, 04:31 PM | #20 |
Rep 45
Not being able to program the M-Mode into the HUD using the M1/M2 button is a step backwards from the F80 - it was so convenient. Maybe a software update will fix this deficiency
08-09-2022, 05:21 PM | #21 |
You got my money?
3158
Rep 4,646
Drives: Ice Cream Truck
What noise control are you talking about? Exhaust?
08-09-2022, 05:28 PM | #22 |
Rep 2,489
sound control for the exhaust
2018 F80 M3 CS
BIGW0RM3157.50 |
