11-23-2022, 06:32 PM | #1 |
Rep 826
Drives: 2022 M3 Competition
Dahler valve controller remote control interference
I bought and installed the Dahler valve controller recently. I mounted it in the same location as noted in the installation video from Kies Motorsports. It's tucked up inside the driver side back area behind the rear quarter panel. It's a wide open space. I tested the controller and it works fine. My issue is that from inside the car the remote and even the homelink mirror button i programmed doesn't seem to always trip the controller to open or close. It's like i have interference or something but i cant think what it could be. I can 100% activate the valve controller if i am near the back of the car. It only happens if i am inside the car for some reason.
I had thought that maybe i could find a grommet and then somehow detach the harness from the DAhler receiver box and relocate the receiver box inside the car in the trunk but it seems dumb that i would need to do that. Has anyone else ran across this issue?
-- Owner of a 2022 M3 Competition AWD in Individual Voodoo Blue and Fiona Red leather |
11-23-2022, 08:24 PM | #2 | |
Rep 60
11-24-2022, 09:09 AM | #3 | ||
Rep 826
Works fine if im outside. <shrug>
05-31-2023, 11:48 PM | #5 |
Rep 20
Any updates on this? I have the same exact issue and have ceramic tint installed... Debating on trying to move the module into the trunk to see if it makes a difference.
06-01-2023, 08:01 AM | #6 |
Rep 826
No updates. It seems to work better if I roll a window down so I think it’s the tint. I was waiting for summer here in Midwest before I tried to relocate the module. If you do move it please report back on if it helped
06-01-2023, 08:41 AM | #7 |
You got my money?
3161
Rep 4,646
Drives: Ice Cream Truck
Certain tints are known to cause this.
06-01-2023, 10:29 AM | #8 |
Rep 1,929
If you open the controller is there a wire dangling in it? That's the antenna, if you can extend it to inside the car it should solve the problem, but then you need to seal the box.
06-01-2023, 10:59 AM | #9 |
Rep 20
Sigh, I see, then I don't believe just moving the controller into the trunk will help.
Good point, but I would assume that the antenna is integrated into the controller itself. But, if it is a wire that I can extend and I move the controller into the trunk, that should solve this issue. |
06-01-2023, 11:46 AM | #10 |
Rep 1,929
It could be integrated but you never know, try opening it up.
So now the VCS constantly fails, the dahler gets stopped by Tint and the Dinan can't be linked to the garage door buttons. We need more options 😂
06-01-2023, 11:59 AM | #11 | |
Rep 1,254
https://www.sst-spezialsteuergeraete...7D1%7B10%7D404 |
forcefed2567.00 |
06-01-2023, 01:48 PM | #12 | |
Rep 1,160
06-01-2023, 01:58 PM | #13 |
Stance to make her dance
708
Rep 2,003
This happens to me sometimes but I usually just click the remote one or two more times and it opens. I think its my tint as well.
INSTAGRAM: thompsac_m3 YouTube: ACCELERATED MOTION
2022 G80 M3 6MT, FEMTO, BM3, KW, AWE, MAD, lots of carbon |
06-01-2023, 02:35 PM | #14 |
Rep 18,823
Awron Smart CanFlap. Fully integrated - no key FOBs or remotes to fumble with, while gaining full control over the exhaust valves with adjustable profiles.
AWRON - Smart CANFlap Exhaust Valve Controller for BMW https://g80.bimmerpost.com/forums/sh....php?t=1991762
06-02-2023, 01:46 AM | #15 | |
Rep 20
06-02-2023, 12:37 PM | #16 | |
Rep 18,823
I've never heard of a valve controller causing an issue that needed to be diagnosed by a dealer yet. The Awron does require tapping into a couple of wires and not need any separate key FOBs. The install is relatively simple for the DIY and is 100% hidden on the installs we perform. Enjoy your car. Keep the mods relatively simple and you shouldn't have any warranty issues.
06-02-2023, 11:23 PM | #17 | |
Rep 20
But, thanks for the good words! |
06-03-2023, 10:52 AM | #18 |
Rep 118
06-03-2023, 12:31 PM | #19 |
Rep 20
Long story short, but I notcied that my door card would rattle and that it was not fully bedded into the door, hence the rattle. I thought it was prob a factory defect or something, so brought in to dealer under warranty (Didn't attempt to fix myself, cause I was like hey, I got warrenty, my mistake....). They told me that they won't touch the door card since I have aftermarket tint, and that they prob messed it up. Dealer said tinters usually pry or pop the top of the door card out when tinting. Tinter said they only usually pry the rubber seal only. It was already at the dealer for 2 weeks at this point, so I just told em to open it up and assess the damage (money out of my pocket for them to do that). They took it off and put it back on and said there is no damage... No more rattle now.
Overall, I should have just tried to pop it back in myself and I woulda saved both my time and money... |
Rodizzle397.00 |
06-03-2023, 04:16 PM | #20 |
Rep 1,929
At this point they can say that because the tinter opened the door card he could have damaged the wiring, and if the wiring was damaged the dme got fried and thats why your engine blew up and the muffler bearings are shot...
06-05-2023, 10:12 PM | #21 |
99
Rep 204
06-06-2023, 08:14 AM | #22 |
Rep 118
I have a dahler unit showing up this week. I will do some inspecting when it arrives to see if this is something worth attempting for me.
