11-11-2023, 12:01 PM | #23 |
PC
53
Rep 52
Drives: 2024 M3CX
Berzerker So would it be fair to say if I eventually want to make axleback choices after midpipe & valve controller, the biggest attributes relevant to me are closed valve state sound and open valve drone fighiting, since the mufflers are different in size/composition vs. OEM (or other aftermarket choices)?
Am I wrong/right to focus on these when comparing OEM vs. AM (or AM vs. AM) axlebacks: 1. Closed valve - how well it eliminates drone, sound through muffler, overall sound level, restrictiveness to airflow, integration compatability to OEM valve controller 2. Open valve - drone elimination (or is that more midpipe?), airflow, sound quality (due to piping sizing/configuration/flow vis a vis the muffler), less focus on this vs. closed? Otherwise for my stated preferences and goals (sound/appearance), does OEM vs. axleback come down to cost/appearance, partially achieveable with AM exhaust tips (plus the diaper effect)...?
'12 F30 335i (Mineral Gray, Black, Sport Pkg), '15 F32 435i (BSM, Black, MPPK), '18 G30 540i (BSM, Black Nappa, M Sport), '21 G05 X5 x40i (BSM, Tartufo Merino, M Sport)
'24 G80 M3 Competition (DG, SS Full, xDrive) Last edited by PYCg80; 11-11-2023 at 12:20 PM.. |
11-11-2023, 09:43 PM | #24 | |
Rep 2,649
There isn't much to deciding on an axleback vs OEM. An AM axleback will increase volume a bit but change the sound slightly so it really depends on what you like, which is why I suggested trying to find something to listen to. Most of the big names (active autowerke, valvetronic, dinan, etc.) have figured out how to eliminate drone from their axleback replacements, so you're fairly safe there. There's been one report of the new MAD axleback having a little drone at 2-3k RPM (which is where most drone ends up happening if it exists). Drone reduction is going to largely come down to muffler quality rather than midpipe. A large decision factor for an AM axleback does, as you mentioned, come down to wanting to remove the diaper look and improved exhaust tips. |
11-13-2023, 03:22 PM | #25 | |
Rep 4,966
Highly suggest using the resonated midpipe in this situation.
PYCg8052.50 |
11-23-2023, 06:24 AM | #26 | |
Gun Nut
216
Rep 87
11-23-2023, 11:30 AM | #27 | |
Rep 477
Can i adjust the valve to whatever percent i want based on rpm or throttle percent? Think something similar to boost by gear. If i could have any setting i'd have it wide open under 2-2.5krpms, close to 20-30% like oem until 2.5-3.5k to avoid drone then open to 50% unless im over 50% throttle. Then a secondary setting of wide open. Whats the cost of the Awron shipped? Last edited by RACE M3; 11-23-2023 at 11:38 AM.. |
11-23-2023, 12:18 PM | #28 |
Rep 25
Drives: 2018 BMW M3
I was in the same situation as you recently. Decided to go for the full catback from MAD. Honestly I can’t be happier with the sound. Changes the car completely with the deep, aggressive sound and the cleaned up back end. Go for the full system and you won’t be disappointed
j_LaSalle_561317.00 PYCg8052.50 |
11-23-2023, 01:22 PM | #29 | |
Rep 190,988
11-23-2023, 01:51 PM | #30 |
Rep 2,649
11-23-2023, 10:47 PM | #31 | |
Rep 18,839
▀▄ eas | AWRON - Smart CANFlap Exhaust Valve Controller for BMW https://g80.bimmerpost.com/forums/sh....php?t=1991762
11-24-2023, 07:33 AM | #32 |
Rep 190,988
Tags |
axleback, exhaust, g80 exhaust, g80 mid pipe, help a noob, m3 exhaust, midpipe |
