11-07-2023, 12:18 PM | #1 |
PC
53
Rep 52
Drives: 2024 M3CX
Total Noob - Looking for Midpipe vs. Axleback Advice, thoughts
Looking for guidance or recommendations between a mid-pipe only or axle-back only as the first and possibly only exhaust mod keeping in line with OEM+. Price and performance are secondary, my main goals are:
1. Limited modification, bolt-on/compatible with OEM. 2. Sound - moderate increase in volume, deeper while remaining smooth, a boost in volume when driving hard. 3. Reliability!!!! Don't want to do any programming or worry about anything outside of plug and play. Am I better off with a midpipe replacement, or axle back only to achieve the goals above? If midpipe, how am I deciding between single, Xpipe and equal length? |
11-07-2023, 12:21 PM | #2 |
Rep 2,648
Either a midpipe-only or axleback-only will require you to cut at the midpipe-axleback joining area. This is normal and is also what BMW does to install the first-party M Performance Exhaust. I would put zero concern in that, specifically.
The recommendation is to start with a midpipe since that gives you the most volume change, as you're removing resonators and secondary cats. It'd be tough to say one kind or another without having you actually listen to them and see which you prefer. Most people like single midpipes the best as it tends to give a more "deeper throaty" sound compared to equal length or X-Pipe (stock midpipe is an X-pipe config). If you think you may swap downpipes in the future (this can cause warranty concerns so I'd only recommend if you don't care about that), it's recommended to get a resonated midpipe. If you're not going to swap downpipes, you can get unresonated. As for axleback, that becomes trivial once you get a midpipe swap as your axleback is already cut from the midpipe, it's just a few screws and some hangers and it's off. Many people actually keep the OEM axleback as it does quite a good job at eliminating drone and is already a straight-piped design with valves open. You'll want to add a valve controller. TLDR: Midpipe first, then decide axleback. |
11-07-2023, 12:39 PM | #3 |
BMW Enthusiast
378
Rep 126
Definitely midpipe first. It makes the biggest difference. I went midpipe, valve controller, axle back, downpipe in that order
CURRENT LINEUP
2018 Satin Blackrock Grey Metallic Tesla Model 3 LR, 2023 Glacier White Audi Q4 Etron, 2024 Black G83 BMW M4 xdrive Competition Convertible |
11-07-2023, 12:58 PM | #4 |
PC
53
Rep 52
Drives: 2024 M3CX
Berzerker and ratedpg909 - these posts are why this forum is gold. Appreciate the sound and clear thoughts.
I'm in LA, so I think maybe it's time to find some of these meetups and other places to try and get an earful in person. My week 45 build can't get here soon enough.... Last edited by PYCg80; 11-07-2023 at 01:00 PM.. Reason: quoted wrong post |
ratedpg909378.00 Syndr782.00 |
11-07-2023, 01:01 PM | #5 |
Rep 154
Anyone have sound clips of the akrapovic Evolution Link Pipe set in titanium with the stock axle back?
I was going to go with AA catted DPs as I don't want a huge sound increase, but think this may be a better route. |
11-07-2023, 01:29 PM | #6 |
PC
53
Rep 52
Drives: 2024 M3CX
Follow up questions on single pipe midpipe mod -
(1) would getting a resonated midpipe defeat the whole purpose if this was your only mod and you were looking for sound deepening/volume? Or do aftermarket ones still offer better sound due to increased airflow, different resonator properties, etc.? (2) do the secondary cat/resonator deletions from changing the midpipe create any regulatory issues down the road (e.g. smog testing, emissions compliance, etc.)? USA, California. Hoping the primary cat staying in place is sufficient if this is my only mod. |
11-07-2023, 01:51 PM | #8 |
Rep 18
11-07-2023, 02:44 PM | #10 | |
Rep 4,966
2.Technically yes but there is no sensors to check the secondary cat so only a visual inspection would be an issue. Never heard of anyone having an issue before.
PYCg8052.50 |
11-07-2023, 03:39 PM | #11 |
Rep 337
So I’ve heard it mentioned that the stock muffler is a straight pipe design, but I’m confused on this. With the valves open, there is still the opening that leads into the muffler, so how is that a straight pipe? Whatever exhaust goes into the other opening is straight piped, but some of the exhaust flow does go through the muffler.
11-07-2023, 03:49 PM | #12 | |
Rep 4,966
When the valve is half way open it does cause some back pressure and forces some of the air through the muffler pipes. With a valve controller the valves are 100% open so the air flows through the path of least resistance which would be the straight pipe section of the muffler. I won't say no air is passing through the muffler but it should be very little if it is. The same goes for our axle back
11-07-2023, 04:10 PM | #13 | |
Rep 2,648
It's not 100% straight-piped, so there's some air that's going to be backpressured into the muffler, but the path of least resistance is straight through to the outside, most of your air is going to not go through the muffler. Pic attached |
PYCg8052.50 EatThatLunchBaby388.00 |
11-07-2023, 10:34 PM | #14 | ||
Rep 337
11-08-2023, 02:13 PM | #15 |
Rep 190,975
I'd start with a single midpipe + sst valve controller
11-09-2023, 12:37 PM | #16 | |
Rep 18,839
ratedpg909378.00 PYCg8052.50 |
11-10-2023, 11:16 PM | #18 |
PC
53
Rep 52
Drives: 2024 M3CX
OK this may have been answered somewhere else, but instead of reading 6,234,342 posts, I bet someone here has the answer:
Is there a way to modify the valves so the OEM/valve control in the center console is retained, but still get the benefits of the aftermarket controller's full open functionality?
'12 F30 335i (Mineral Gray, Black, Sport Pkg), '15 F32 435i (BSM, Black, MPPK), '18 G30 540i (BSM, Black Nappa, M Sport), '21 G05 X5 x40i (BSM, Tartufo Merino, M Sport)
'24 G80 M3 Competition (DG, SS Full, xDrive) |
11-11-2023, 12:50 AM | #19 | |
Rep 18,839
▀▄ eas | AWRON - Smart CANFlap Exhaust Valve Controller for BMW https://g80.bimmerpost.com/forums/sh....php?t=1991762
PYCg8052.50 |
11-11-2023, 04:58 AM | #20 |
Rep 19
Regarding the discussion on valves and muffler function, so single midpipe with valve control set to fully open should sound the same on stock vs aftermarket mufflers? Since they are both acting like straight pipes with valves 100% open?
Im deciding on whether axle back is worth it. I have a MAD single with SST valve controller. |
11-11-2023, 11:13 AM | #21 |
BMW Enthusiast
378
Rep 126
Nah it won’t sound the same. I had the valve controller and midpipe first then added the axleback. It was noticeably deeper with the axleback and less burbles at lower speeds than stock. It wasn’t much louder at all.
CURRENT LINEUP
11-11-2023, 11:33 AM | #22 | |
Rep 2,648
A third-party muffler will also have smaller silencers, maybe thicker or thinner pipes from the midpipe, different thickness of the walls, different shaper, travel distances for the air, etc, etc. There's a lot of changes that can be done with an axleback swap. What the OEM axleback does a good job at is reducing/eliminating drone while not decreasing the sound all that much because of the flaps-open state being *mostly* straight-piped. A valve controller, as you have, gets you fully opened valves too, completing that kind of "setup" If you want a bit more volume with more things like pops/burbles to be more pronounced, an axleback swap might be worth it, but you really should try and find one to listen to so you can compare. Try checking out your local cars & coffee. |
PYCg8052.50 |
Tags |
axleback, exhaust, g80 exhaust, g80 mid pipe, help a noob, m3 exhaust, midpipe |
