| 11-17-2025, 01:00 PM | #67 | |
![]() ![]() ![]() 421
Rep 453
Backed up comparisons by customers though, will certainly help to provide us context. |
///M4Lou2303.00 |
| 11-18-2025, 02:01 PM | #68 |
Rep 8,542
Posts ![]() |
We’re developing a new S58 intake for the G80/G82/G87 that includes larger turbo inlets and these inlets will only fit our intake due to their increased size. This setup is designed for maximum airflow, better response, and improved efficiency, especially for tuned or hybrid turbo cars.
Right now, the only company offering an intake + oversized inlet combo is DO88, and theirs is carbon fiber (and pricey). We’re offering a similar concept in aluminum to keep costs down while delivering the same performance benefits. I also have a set of oem fitting upgraded inlets if anyone wants to test for us please reach out.
- Click Here Performance Parts For Your Bmw At Crazy Low Prices! 5% OFF Code "BimmerPost" Email: info@mad-us.com |
GolfCoyote2174.00 Dnshift213.00 |
| 11-18-2025, 02:41 PM | #69 | |
Rep 183
| 11-18-2025, 02:45 PM | #70 | |
Rep 8,542
Posts ![]() |
Something for everyone. ![]()
| 11-18-2025, 03:03 PM | #71 |
Rep 136
| 11-18-2025, 03:23 PM | #72 | |
Rep 8,542
Posts ![]() |
| 11-18-2025, 03:47 PM | #73 | |
![]() ![]() ![]() ![]() 2174
Rep 963
Interested to see what this new system you’re cooking up is.
2024 M3 Comp xDrive (725whp/636tq)
2023 Mach-E Premium AWD |
| 11-18-2025, 04:00 PM | #74 |
Anesthesia
1711
Rep 784
Mishimoto provides an oversized inlet with their intakes. However, they only added the passenger side turbo inlet, as their bench flow tests shows negligible difference on the front side turbo.
BeemerBoost118.00 |
| 11-20-2025, 08:21 PM | #75 |
![]() 2303
Rep 1,791
Yeah - I run them. If you watch the video from them, the passenger side is increased (flow) like 20% and driver's is 10% (or so). Makes you wonder if they'd redesigned the drivers side inlet, it'd been more. I like the Mishi inlet for those of us that cannot afford the 3k eventuri...
| 11-20-2025, 11:06 PM | #76 | |
![]() 195
Rep 297
2026 M4 Miami Blue | Build Journal
[/URL] https://g80.bimmerpost.com/forums/sh...0#post32111100 2024 X5 40i Skyscraper Gray (Wife's car) |
| 11-21-2025, 08:22 AM | #77 | |
![]() 2303
Rep 1,791
| 11-25-2025, 04:14 PM | #79 |
Rep 206,096
Posts ![]() |
i dont think i have seen third party dynos with only the inlet as the difference.
https://x-ph.com/sale/ Phone number 725-221-5267 ![]() |
| 11-26-2025, 01:27 AM | #80 | |
Rep 453
I'm now going hybrid turbos, so will be fitting the MMX inlets as part of that, as advised by my tuner. |
| 11-26-2025, 04:35 AM | #81 |
Rep 130
Drives: 2026 BMW M3 Comp 2025 BMW M2 2026 Toyota Supra FE
Just ordered from x-ph.com
Will see how they work with front mount intakes and catless downpipes. Last edited by wax50; 11-26-2025 at 04:37 AM.. |
mike@x-ph.com32786.00 |
| 11-26-2025, 09:14 AM | #82 |
![]() ![]() 6867
Rep 5,312
This isn’t really a mod you do for more power, it’s an efficiency and response mod to basically allow the turbos to work a little less to pull in the same amount of air or more through the intakes. It’s done to lessen pumping losses, which in turn will get you more performance. This is one reason why a couple of aftermarket intakes encompass these already as part of their system, because there’s some restriction in the stock pieces.
AlpineG05761.00 |
| 11-26-2025, 09:46 AM | #83 | |
Rep 963
I don’t doubt this might reduce WGDC or let the turbo spool up a tiny bit quicker, but is any of this a measurable/meaningful amount? I suspect not, and unless you’re out their chasing tenths of a second this isn’t going to be a noticeable mod. This platform is strange in that there is very little data by the aftermarket companies for parts they put out. I’m used to companies including actual dyno graphs or flow charts for parts(heavily biased info I’m sure but still it’s something), not just this whole “it does stuff, trust is bro” way of marketing.
| 11-26-2025, 10:48 AM | #84 | |
Rep 206,096
Posts ![]() |
| 11-26-2025, 11:07 AM | #85 | |
Rep 8
| 11-26-2025, 06:27 PM | #86 | |
![]() 104
Rep 181
What is this T51 Turbo Mod I keep reading about? |
| 11-26-2025, 06:29 PM | #87 |
Rep 136
| 11-27-2025, 04:27 AM | #88 | |
![]() ![]() 248
Rep 316
The DME limits power in stock form...most modern cars actually do this. The OEM calibration allows a max amount of torque/hp and will limit timing, throttle, wastegate duty etc to keep power below the threshold. So even if these add power, which they do when tuned and turning up the boost, they are mostly useless on a stock tune. The only advantage is if you have aftermarket intakes for the sound, these inlets will give you a louder bypass valve "woosh" sound over the stock inlets. Now tuned, without the DME limiting the power, these inlets reduce WGDC. Pair it with downpipes, mid, intake....they all reduce the work the turbo has to do. This will result in more power and a faster car than tuned cars without these mods. Simply because you need less exhaust to go through the turbines to reach boost levels which results in a less restrictive path for the exhaust to exit.
Owner, Snackbar Tuning
DLSJ5703.50 |
| Bookmarks |
