| 08-12-2025, 11:59 AM | #1 |
![]() ![]() ![]() 1332
Rep 429
Upgraded Turbo Inlets --- Worth it?!?
Hey everyone,
i just saw the MMX dropped these upgraded turbo inlets! it might be to soon but wondering if anyone has installed them yet and have any feedback?!? https://ind-distribution.com/collect...nlet-elbow-set |
| 08-12-2025, 12:32 PM | #2 |
Rep 183
...Iam curious about this as well...do these make a difference?
I have been eyeing the ftp turbo inlet pipes...as I would like to use the oem style dropin air filter and housings. https://www.ftpmotorsport.com.tw/pro...m3m4-g81g80g82 Last edited by Boost112; 08-12-2025 at 12:37 PM.. |
Lenny-ontop1.50 |
| 08-12-2025, 12:41 PM | #3 |
![]() ![]() 6867
Rep 5,312
These are probably very similar to the integrated ones that come with the Eventuri intake. None of the pics show the inner construction or the smoothness/transition of the velocity stack and pipe flow inside, but if done right, regardless of the turbo opening still being the same, some benefit can be seen. Mods like this are usually done as a “response” mod… in other words, it’s about easing the difficulty the engine/turbos may have in their ability to take in air. If there is a restriction, even a minor one, that eased, then you should see a benefit. It’s also not about the HP gain… a gain in responsiveness and efficiency in lowering pumping losses can also be felt and would aid in a performance gain. Whether $4xx is worth the returns, hard to say until you actually do it, but I know on the M5 engines, the Dinan turbo inlets make a difference in the aspects I mention above and the concept is the same here to an extent.
forcefed5117.00 |
| 08-12-2025, 12:44 PM | #4 |
![]() ![]() 639
Rep 314
im going to do it soon...i have gruppeM intake and comes with stock factory turbo inlets so i wanna upgrade them.
2022 G82 Signal Green M4 Competition XDrive
| 08-12-2025, 02:06 PM | #6 |
![]() 89
Rep 252
| 08-12-2025, 02:27 PM | #8 |
salty cowboys fan
8398
Rep 4,102
I would be surprised if there was any difference at all. If it’s meant to fit with the OE intake and turbos, the diameter of the openings will be the same, and it’s such a short section otherwise. Not sure what opportunity there is to milk something out of those constraints.
| 08-13-2025, 10:45 AM | #9 |
Rep 206,096
Posts ![]() |
its going to improve the air flow, but im not sure you will notice a difference on stock turbos unless you push the car 700+ whp.
https://x-ph.com/sale/ Phone number 725-221-5267 ![]() |
| 08-15-2025, 02:36 PM | #11 |
![]() ![]() ![]() ![]() 2174
Rep 963
I know on my old MK7 GTI turbo inlet pipes made a nice little improvement. Nothing earth shattering but it all adds up.
Whoever buys these should take one for the team and do a before/after dyno to see what, if any, difference there is.
2024 M3 Comp xDrive (725whp/636tq)
2023 Mach-E Premium AWD |
boogata175.50 |
| 08-20-2025, 11:52 AM | #12 |
Rep 429
having them installed next week (Tuesday)!
i will say the quality/packaging is gorgeous!! i also bought the MMX intake tubes to match. https://g80.bimmerpost.com/forums/at...1&d=1755708438 https://g80.bimmerpost.com/forums/at...1&d=1755708568 |
M4_lgnd639.00 GolfCoyote2174.00 |
| 08-21-2025, 01:29 PM | #15 | |
Rep 429
but i will forsure do some logs, weather has been pretty cool at night here in NJ, so im going to get some logs done on e50-55 and take it from there. |
| 08-23-2025, 10:43 AM | #17 |
Rep 206,096
Posts ![]() |
looking forward for your feedback
M4_lgnd639.00 |
| 08-26-2025, 01:47 PM | #19 |
Rep 8,542
Posts ![]() |
Anyone up for doing some logs?
I’ll send you a set of our cast turbo inlet elbows to test out. Note: These will only work with aftermarket intakes. Reply here or shoot me a PM if you’re interested.
- Click Here Performance Parts For Your Bmw At Crazy Low Prices! 5% OFF Code "BimmerPost" Email: info@mad-us.com |
| 08-26-2025, 02:04 PM | #20 | |
![]() 152
Rep 161
| 08-26-2025, 02:16 PM | #21 |
Rep 963
FYI, FTP also sells these (but for about $100 less) and actually provides dyno information and power gains.
FTP inlet pipes
BeemerBoost118.00 TopJimmy7440.00 |
| 08-26-2025, 02:20 PM | #22 | |
Rep 830
| Bookmarks |
