09-04-2023, 02:49 PM | #23 |
Rep 86
Anyone try running these?
https://www.racewerkz.com/products/f...e-19-wheel-set It looks like they’ve done the R&D for fitment and require small spacer, but they don’t specify exact size. |
09-05-2023, 08:10 AM | #24 |
Rep 283
It's interesting the supercsr 3rs wont fit when specs if the nankang on paper give the same size section 12.3" measurements using a 11 inch aa the supercar 3rs. Supercar have rim guard and high lettering or is one wrong on the spec sheet?
09-07-2023, 03:31 PM | #25 | |
6923
Rep 3,276
Drives: E46 M3 Coupe/G80 M3CX
09-07-2023, 07:02 PM | #26 |
Riding the knock sensor
2429
Rep 1,614
Drives: 21 X5MC | 23 M4CSL
I'm still on stock wheels but will be trying 19x11 305 square in a few weeks. I want to run the SC3R which I'm told fit like a 320 - so still not sure about the front. This setup assumes you have coilovers/camber plates at the least, and possibly front castor adjustment (ie SPL links).
09-07-2023, 09:27 PM | #27 |
Rep 283
SC3R on a 11 wide wheel will have a section width of 313mm plus any raised lettering.
This does raise the question I have to the OP whereas they say SC3R was never gunna happen using a 10.5 wheel which brings the section width to 308mm. Yet apex wheels has no problem fitting while having NT01s 305 35 18s that happen to also be 308mm. I would be curious where the interference is. I plan to run 10.5x19 all four corners and would like to know why not all 305 30 19 tyre fit. Apex can do it with a 0.2" taller setup, so why cant 19s |
09-09-2023, 05:08 PM | #28 | |
Rep 81
I went through all of this myself and almost pulled the trigger on the 10.5 X 19 wheels, but then just decided to stay on the OEM wheels, because you're really just getting a little extra width up front. Plus even if you do rotate your rear wheels to the front, you still may only get about 20-25 heat cycles out of them = about 4-5 track days. This can also be done with the OEM setup by rotating the wheels side to side.
2021 G82 M4 6MT
2022 G07 X7 40i 2017 G30 530i |
09-11-2023, 08:53 AM | #29 | |
Rep 283
09-19-2023, 01:36 PM | #30 | |
Rep 396
09-19-2023, 01:43 PM | #31 |
2429
Rep 1,614
I should have mounted late next week and will report back.
09-19-2023, 06:59 PM | #33 |
Rep 86
Do you mind explaining your comment a bit more in detail? I’m asking because 305s x 4 seems to be the way to go, and at least one shop has test fit and lapped with this setup. They’re using a small spacer (I don’t know the size) and I’m told it works. But if you’ve got some additional intel, I’m interested. Thanks!
09-21-2023, 05:03 PM | #34 | |
Rep 14
09-29-2023, 06:19 PM | #35 |
2429
Rep 1,614
I know I'm late on the update but Fedex held 1 rim for 5 days. I did have 2 tires mounted this morning in order to check fitment. So far, the rear looks good at 11et which is the rim offset, so it's the max offset I can get. The SC3Rs do protrude slightly at 2 degrees of camber but should clear when compressed (will test soon). On that note, the SC3Rs are very wide - I have a mounted 305 PSC2 and will measure the difference but it's significant. I tried to mount the front at 11et (no spacers) and the bulbous sidewall of the SC3R just contacts the strut body. Min spacer I have on hand is 10MM so I did a short drive with it but it is clear that when compressed the tire could contact the fender.
I just ordered 3MM and 5MM spacers to see which works best and should get tomorrow (thanks tom @ eas) . I did a full lock to lock test driving slowly and the rearward side of the tire just brushes the liner. The smaller spacer will help but intend to deform it in with a heat gun to give a bit more room. As for the front liner, I already have some minor trimming, 3 of the louvers in the middle of the outboard vent were removed and small trimming of the outer rib. It did not seem to rub but plan to trim or deform that area to get more room. The front camber is at 3 degrees but will likely add .5 - same with the rear, to be at 3.5/2.5 Rims are 19x11 11et with SC3R 305/30. It really is pushing, and possibly exceeding, what is advisable but I won't know until I drive it hard - possibly Sunday Preview pic is with 10mm spacer - hoping 3mm will work and should know tomorrow if UPS doesn't disappoint.
Jon H396.50 D_SheerDrivingPleasure1104.50 coldsteelrain820.00 tom @ eas8310.00 BrendanZ0402286.50 Blk5er3324.00 |
10-02-2023, 10:58 AM | #36 |
Rep 92
I am also attempting 305/30/19 3Rs on my G82 xDrive. Millway camber plates with 3 deg camber up front and OEM suspension. 19x11 wheels with total of ETA 7 offset after spacers. Still don’t trust it for track use and some rub inside on full lock. Going to test some more around street before trying on track.
10-07-2023, 10:10 PM | #38 | |
Learning to drive again
792
Rep 351
Drives: M3CS
Also, don't you think you might be giving up too much of the directness of the steering with such wide tires? Turning radius is already bordering on bad IMHO, I cannot imagine it with 305s on 11"wheels. If it actually works, it would be a great setup though. Thank you for trying
Cheers,
BoB |
10-16-2023, 10:18 AM | #39 |
2429
Rep 1,614
I went with the 3MM spacer in the front - so total offset of ETA 8 in front and 11 in the rear.
10-16-2023, 11:21 AM | #40 |
Chief Petty Officer
647
Rep 520
Tested it on track or under heavy load yet? Rubbing or clearance issues?
10-16-2023, 11:54 AM | #41 | |
2429
Rep 1,614
Regarding lock-to-lock fender liner rubbing, keep in mind that 305/30 is about .5" smaller diameter than the stock tire diameter, so that helps tremendously and has not been an issue. Also, there is no correlation between tire width and turn radius. Turn in at zero front toe feels incredible but there is some tramlining on grooved highways, and resistance to centering when on a highly crowned road. I do think the turn in feel improvement has a lot to do with the stiff sidewalls of the 3Rs. Rear is not an issue at ETA 11 but the CSL is a lot lighter, particularly in the rear. I would never consider this setup on a car I intended to have rear passengers. It is a very close fit, so your setup precision - wheel et and/or spacers, and camber matter most. In my case front ETA of 8mm is perfectly centered with a few MM clearance to the strut on the inside and about the same on the outside to the fender under compression. If this bothers you (or are not into fine tuning et, ride height, and camber yourself) go with 10.5, or at least a different brand 305 as the 3Rs are wider than others with a noticeably thick/bulbous sidewall.
FriedPiston1976.50 BackOnBlack792.00 D_SheerDrivingPleasure1104.50 Blk5er3324.00 nizona34.50 Hendo741646.50 M4LAKA118.50 |
10-16-2023, 12:30 PM | #42 |
Rep 2,712
Thank you for your contributions BulkBen and Hit_Apex
It looks like the sweet spot for this setup is 19x10.5" ET10, -3 front camber, along with your choice of 200TW (or less) 305/30/19 rubber. |
10-17-2023, 08:20 AM | #43 | |
Rep 81
2021 G82 M4 6MT
10-17-2023, 08:22 AM | #44 |
Rep 81
Isn't 305 too meaty for a 10.5 inch rim? Max recommended size for a 10.5 is 295, no? It would be nice to run 305 RS4's on a 19 X 10.5 square setup.
2021 G82 M4 6MT
