01-10-2023, 04:46 AM | #1 |
Rep 290
305’s on the front
Hey Guys, after much playing around with wheels and tyres, I’m now quite sure a 305 will work on the front of a G80 for the track. See pics below.
This is great news for those of us keen to run a 305mm square setup - as I am. This was always my plan for the track, made sense given a 275mm tyre with a 20mm spacer works fine, a 305mm shouldn’t be an issue. I first tried with Supercar 3R’s which was never going to happen. These 305’s measure out at 335mm - ridiculous. I’ve since moved to Nankang AR-1’s and todays fitment looks very positive. Like everything when you’re running tight tolerances, offset is critical. My rims are 19x10.5 with an ET14. With the Nankang I’d estimate I’ve got 3-4mm clearance from tyre to strut, so I may end is using a very thin spacer. I’ll measure up properly snd let you know. At this stage I’d say an ET of 10-12 would be perfect for a 10.5 inch rim running this tyre. Outter guard clearance does not look like an issue at all and that’s with only 2 degrees camber. Pushing this to 2.5 or 3 degrees (which is better for the track) will only make outter guard clearance easier. Unfortunately I’ve now got to order 3 more tyres and next track day is a month away, will keep people updated though. Last edited by BulkBen; 01-10-2023 at 05:04 AM.. |
9
PLF693804.00 Devils41297.00 sly1types459.00 D_SheerDrivingPleasure1310.50 coldsteelrain828.00 Jackie Chiles1004.50 FriedPiston2010.00 pateke288.00 nizona45.00 |
03-02-2023, 04:30 PM | #3 |
Rep 989
Nice that should reduce understeer.
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
03-03-2023, 12:35 AM | #4 |
#Driver
397
Rep 439
Money on the 305 square.
2016 Focus RS - ende | 2017 718 Cayman - ende | 2007 911 C4S - ende | 2017 Macan - ende | 2015 Macan Turbo - ende
2023 M3xdrive | 2020 Macan insta: gtsdaddy |
03-07-2023, 11:15 AM | #7 | |
Rep 1,843
03-07-2023, 11:49 AM | #8 |
Rep 2,705
Only one way to find out 😏
g80z691.50 evanescent031041.00 |
03-07-2023, 01:25 PM | #9 |
Rep 290
Quick update.
I finally hit the track with this setup and all seems fine - certainly no clearance issues. The AR-1’s are renowned for requiring bedding in, so after the morning on street tyres I only gave them two quick sessions before packing up. In a few weeks I’ll be back out having fun them for a proper day. Nothing really to report apart from the obvious that they’re much noisier and feel heavier in the steering vs the 4S, I consider the feel a good thing. Those who’ve driven with big, flat track tyres will know what I mean. I do have sone other observations though, not tyre related. On the track 4WD is much better than 4WD sport. I tried this for the first time on the 4S’s and the car became much more taily, really lacked stability vs normal 4WD mode. Secondly, for those trying to get away with the 4S on the track, be careful. I thought mine looked relatively unscathed after my first putting a few months back, however they quickly disintegrated this time out with a front delaminating. They absolutely won’t hold up for multiple track days unless you’re a novice. They’re a great street tyre but a big heavy car like the G80 driven in anger will shred them. |
03-11-2023, 04:32 PM | #10 |
Rep 14
Hey BulkBen. If I wanted to run a 11j front with 305 30 20 tyres. What offset would u recommend. I like the aggressive sticking out a little look. But dont want to catch the front wings, or Fenders as I think you guys call them!
Also offset for rear with same wheel and tyre would be helpful, thanks. |
04-11-2023, 05:30 AM | #13 | |
Rep 371
Cup2's will probably do it for me. |
04-11-2023, 09:37 AM | #14 |
Rep 72
So I have the 2 GYSC3R sitting and I don't want run 305 in front (I guess we can't unless camber plates) so looking at the tire diameter 265/35/19 SC3R matches the 305. Can I run 265/35/19 on 10" wheel upfront and 305 in rear on 11" wheel to keep the xdrive happy. Please share your thoughts. Thank you.
05-02-2023, 01:53 PM | #17 |
Rep 924
I wonder how positive your scrub radius is from adding 30mm of width presumably all outboard of the center line. Thats probably the heavy steering feel you are getting.
Did the car do anything weird under braking on corner entry? Scrub radius would improve (get back to negative) with camber plates and more inboard steering angle to compensate for the change of wheel center point.
2023 F90 M5
07-21-2023, 01:41 PM | #18 |
Rep 88
Do you think the 305 square setup will work with 11 inch wide wheels? I’m looking at the Apex VS-5RS either the 19x10.5 ET 18 or 19x11 ET 22. I’m thinking to go with the 11 inch wheels since it would fit a 305 better.
07-21-2023, 02:41 PM | #19 | |
Riding the knock sensor
3124
Rep 2,003
Drives: 21 X5MC | 23 M4CSL
07-21-2023, 08:50 PM | #21 | |
Rep 88
09-03-2023, 08:49 PM | #22 | |
Rep 423
