05-28-2014, 12:42 PM | #1 |
Rep 8,942
FYI on stock rim pricing
Might need to replace my front right rim, MSRP is $489.66. Will have Sun order it up for me if need be.
05-28-2014, 12:47 PM | #2 |
Rep 304
Drives: M235i Alpine White
What happened?
05-28-2014, 12:53 PM | #3 |
Rep 8,942
Was driving on a road I didn't know, which was all black because it was wet and tree covered so shadows everyplace, and hit a pothole. Got a huge bubble in the tire, fingers crossed on the rim but who knows. I think Sun will do the rim shipped for around $400 so it's not as bad as I feared. $600 per corner (wheel and tire) means you need to destroy 4 before the tire insurance starts to pay for itself. It's still holding air and it's been 5 days, so the seal is fine which I hope means the rim might be ok.
05-28-2014, 03:25 PM | #5 |
***** noob
1370
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Oh No
Sun have it for $400? Maybe i should get a square setup for winter
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
05-28-2014, 03:32 PM | #6 |
Rep 304
That tire blister does not seem too bad. The tire is done but I would doubt the wheel was damaged.
05-28-2014, 03:42 PM | #7 | |
Rep 8,942
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
05-28-2014, 03:42 PM | #8 | |
Rep 8,942
2022 Macan S
05-28-2014, 04:12 PM | #10 | |
Rep 8,942
2022 Macan S
05-28-2014, 04:54 PM | #11 |
Rep 148
I was just making calls to see if anyone offered the regular "Road Hazard Coverage" for new car tires. Companies that used to offer it for new cars like Tire Kingdom and Tires Plus no longer provide coverage. Those usually only cost $25-30 per tire....the dealer prices are just crazy.
05-28-2014, 05:26 PM | #12 | |
Rep 8,942
2022 Macan S
05-28-2014, 06:28 PM | #13 |
Rep 1,040
You can get by driving it at normal speeds for a while. I put 1000 miles on tire that had three of those size bubbles before . The longer you do drive with it the more chance you can damage the rim with the spot with the bubble now being a weak spot in the tire and will give more.
Go to know that Sun Motors can hook us up for a full set of factory wheels for $1600 or less. If you get another bubble incident in a different wheel you might want to bite the bullet and go non-runflats all the way around. |
05-28-2014, 06:47 PM | #14 | |
Rep 8,942
2022 Macan S
05-29-2014, 06:33 AM | #16 |
Rep 8,942
Thanks for the heads up, my dealer told me the same and their wheel guy comes in on Mondays. Wanted to do some research and figure out pricing, best source etc. just in case. Plan is tire shop Friday and be done if wheel isn't bent, dealer Monday to see if wheel can be fixed if it is bent, then order rim from Sun and have shipped to dealer for install on following Friday if it can't be fixed. All in order of increasing cost and hassle, obvs.
